Sylvania 13 When I put in a VHS tape it kicks it right back out. Suggestions?
    Brigadier General:
  • 6,966 Answers
This is an electro/mechanical problem which could be:
1. cut/slipping belt;
2. gear mechanism;
3. foreign object lodged inside;
4. drive motor/pulley;
As you can see a number of possibilities. Since this would involve opening the unit (a bit complicated with combo units), perhaps your best bet wold be to seek the services of a qualified professional. Sorry but no easy fix for the user. Actually the difficult part is not fixing but rather disassembling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
  • 1,512 Answers
It will have a mechanical problem in the transport whereby it is not fully loading, If you have kids, pop the door up and see if there is anything dropped down inside it. If the load assembly has a problem, then they can be replaced as a complete part. You may need to get a tech to look at it for you. If you want to do it yourself, I can help you get the parts, and talk you through it.
robotek
    Genius:
  • 2,785 Answers
Plz try with another one, if the problem persists then you have to send it for repair
1) 70% of the time, I put any VHS tape into my Sylvania DVC840E DVD/VCR Combo, the VCR immmediately kicks the Tape right back out again. Majority of the time, I have to push the tape in at least 4 or 5...
There is a mode switch operated mechanically after inserting the VHS tape. Locate it. First try using switch cleaning oil. If it does not work, then the mode switch has to be cleaned using very fine polish paper (specially used for cleaning electronic contacts) after dissembling.Warning:-Removing & fitting the mode switch is very tedious job. The sequence in which it operates is important. If the sequence goes wrong, it will damage the gears. If you are not sure do not carry out these repairs on your own. It is better as it is now. Try to get the service manual.
sonsunny
Jul 02, 2011 | Televison & Video
Tip
How to eject a stuck vhs tape.
I will show you how to eject a stuck vhs tape. I did this on the sony slv-d300p first, unplug it. Next, take out all the screws on the back. Take off the cover. Locate the loading motor on the right. Turn the gears next to it. After about 5 minutes, the tape should eject. While its open, take a CLEAN piece of paper, hold it up to the drum, and rotate it with the paper against the back. after 5 minutes, take the paper off and stop spinning. the paper may be dirty. put the cover back on, and try to put in a vhs c adapter with NO vhs c in it. when you put it in, it should spit it back out.
on Jul 15, 2010 | Televison & Video
When I put in a VHS, the power goes off and when I turn it back on, it ejects the tape.
It has a tape transport problem. It shuts off to avoid any damage. It probably is not loading the cassette all the way in.
Apr 21, 2010 | Sylvania DV220SL8 DVD Player/VCR
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Sylvania srd3900 error 2
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
Nov 30, 2008 | Sylvania SRD3900 DVD Player/VCR
Dejar solamente la TV
you have a Philco, TV\VCR Combo Your problem is the VCR.The rubber band that pulls in the Vhs tape and kicks it out is stretched,
or damaged. The TV turns off to protect itself. You need a replacement.If u know how to get inside,look at the right side of the VHS section [you will be facing the back of the TV] be careful! "Electricity HURTS. It will be very hard to find the replacement VHS rubber band. There are 3 bands, replace them ALL!!, not just the damaged one.
Apr 25, 2008 | Symphonic SC3813 13 in. TV/VCR Combo
Tape ejection malfunction
The problem may very well be a slipping spool idler that does not tension the tape properly when trying to eject. Try cleaning the rubber friction surfaces or replacing the part....accordianman
Feb 15, 2008 | Sylvania 2870LV VHS VCR
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
