Question about Acer Aspire 3100-1405 Notebook
Slow...slow...and slower Well..my Aspire 3100 is offically over a year old, and gosh did it loose its speed. I have not recently installed anything new to my laptop that could make it run any slower. I actually just got it back from the manufacture; they were fixing the keybored..and since I got it back it has been runing very slow. I have deleted all temp internet files, and I even ran it for spyware like a million times. I'm thinking of degrading from Vista to XP, but I do not want to go through the trouble if there is a solution to my problem. I mean it used to be fine...but now even youtube would not play for me..it loads, but does not play correctly. Please help!
    Genius:
  • 2,785 Answers
You check for viruses by disabling the system restore
Posted on Jul 02, 2008
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Why is my Aerolite mobility scooter lacking speed? I have had it recently serviced and they found the speed controller loose, They said they fixed it. But now its slower then before what can be wrong?
hi Steph , the speed controller being loose would not affect speed unless there is a bad connection now ...in most cases it's either brushes or brake not releasing 100% or the motor has become retarded sadly...
if it has a 4 to 8 mph switch make sure the cable to the controller has not been damaged ...
Regards
Rob
Dec 18, 2015 | Health & Beauty
System booting very slow,system performance very slow
just install ccleaner avail download 4 free and run cleaner and it removes all unwanted files and corrupts in disks and right click on c: properties>tools>defragmention process which removes bad cluster on ur disk which makes ur system slower
Jun 28, 2011 | Computers & Internet
Firefox slow, why
"Fast" or "slow" is a subjective and unscientific description. If Firefox is not running at the speed it usually does, you should try disabling any add-ons you have recently installed and see if the problem corrects itself. If Firefox does not perform in the way you expect it to on a given computer, the computer may be equipped with a slower processor or less RAM than you are used to.
Sep 06, 2010 | Canonical Ltd. Ubuntu
My 5 year old computer is getting slower and slower, takes 5 - 10 minutes to boot up in the morning, is slow to open up attachments and move from application to application.
Most likely due to low available disk space on the hard drive. Items like system restore and the fact that windows does not report partially used clusters as Used (If any part of a file is written to a cluster, that cluster is dedicated to that file regardless of how much is not being used, even though windows reports it free)
So freeing up disk space is one option.
You can also use applications like Advanced System Care to tune up your system
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=contentMain;contentAux
Jul 20, 2010 | Dell Dimension E510 PC Desktop
I recently just got a MSI U100-843 and having video problems
The problem could be from your internet connetion, I think your internet speed or Mbps is slow. Although system speed also has a great role to play.
So check your system memory and processor speed if it is up to standard likewise your internet connection. The problem is from either of them.
Also compare your friends compaq notebook system configuration and internet connection with yours. I believe you would know where the fault is coming from when you do this.
I use my office server to browse with my laptop and the server speed/Mbps is 100. Its usually very fast when I download. I noticed later that it gets slower between 9:30 am and 5:00 pm when alot of people are using the server in the office, so what I do is to stay back when most people must have gone and server will be fast then.
Why I am sharing this with you is because, maybe the internet server you are using gets congested as a result of many users, so maybe you should try in a time when you know most people are off the server.
I wish you the best of luck.
Dec 01, 2009 | MSI Wind U100-030US Laptop
Acer3100 laptop comes on but no screen
Fan needs to be clean plus your CPU clocking must be check by expert. Power supply is good? did you take a look at it? Under the laptop required Power shows, if your AMP loose or less your laptop will
faintdown. Your battery migth also **** all the power so laptop performans gets down. Your lcd inverter also could be faulty. Bad caps also issue for this, You need OHM meter to test some power issues.
Goodluck or show to expert
JMC
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Computer running much slower - Not responding.
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Jun 02, 2009 | Acer Aspire 5735 Notebook
Acer Aspire 5580 suddenly slowed down
Your acer is infected with virus that current antivirus cannot detect. uninstall new application programs that make your computer slower. however if non of those causes; please try to check the memory maybe is not function well. if it is not the cause then; You should reinstall your system to fixed all error on it. ( note: reinstalling will remove some important files and you should back up) Further more; the best thing to do is format the HDD and install the new windows.
Harry: take note: that other causes of the computer slower is the HDD , I encountered 50 times problems that computer become slower bcoz of the hard drive mulfunction. If this is the case you should replace hard drive that is covered with warranty.
Jan 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3100-1405 Notebook Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
