Question about KitchenAid KSRS25IL Side by Side Refrigerator
Freezer Door Stuck Shut
My side by side Model KSRP25FNSS00, freezer door is stuck shut. Have no idea what happened. Just tried to open it to get my nightly ice cream snack, and the Obese Fairy has fixed it where it won't open. Please help.
  • sanicle Jul 02, 2008
    I decided to empty the ice cubes using the door dispenser. After the ice cubes were emptied, the freezer door opened. No more problems with it last night or today, I've checked it many times. The freezer remade new ice cubes and they are dispensign correctly.
    Sergeant:
    Champion:
  • 330 Answers
The refrigerator with 2 doors, the freeze has a electronic magnetite automatic close system, I think your electronic relay got problem, it doesn’t automatic relieve, you can try to unplug the electrical plug see if you can open it, after you open it and plug the plug back and try to close it again, if it is works, that’s great otherwise you have to fix it .
Good luck.
Frank
Posted on Jul 02, 2008
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Refrigerator problems 2-door freezer door stuck will not open
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
Mar 01, 2015 | Frigidaire FFHT1715L 16.5 cu. ft....
Freezer Lights Shut Off
The switch may be stuck, it's on the door frame somewhere. Check the bulb, too.
Nov 26, 2013 | Miele Refrigerators
My refrigerator beeps every five seconds...then repeats in a minute. I checked that both doors are shut and nothing is blocking the shutting doors.
try checking to make sure the door button is not stuck when you open the door. The beeping means the indicator is reading an open door. Also check the freezer side.
Jul 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
Freezer door won''t open, was frozen shut, used a hair dryer and then could open but now it doesn't open all the way and seems to stuck on left side.
take defrost the freezer it sounds like ice has builded up behind the door and it sounds like u may need a new door gasket or it didn't get closed all the way.
here is something u can try to see if the gasket seals take a dollar bill put in the door frame shut the door if the dollar bill comes out easy the gasket is not sealing
Apr 02, 2011 | GE Profile Stainless Bottom-Freezer...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Feb 29, 2008 | Whirlpool GS6NBEXR Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
347 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
