Question about Dell Inspiron 2200 Notebook
I dont have a sound recording or volume for my lap top since i installed a new window
    Genius:
  • 2,028 Answers
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Mute on hp lap top how do I fix it?
Did you re-install windows? If so did you install the driver? If you haven't, go to the volume mixer and make sure the volume bars are dragged up!
Nov 03, 2012 | HP Computers & Internet
Iam not having the audio device in my lap top unable to raise the volume or remove the mute itry to remove the mute in control panel clicking the option of sounds but didn't work out they said...
it seems that your windows did not installed properly. some files may be missing. so you should repair your window from the windows cd and then check out your volume control option. If still it would not work then check out the audio drivers.
May 30, 2011 | Computers & Internet
Good Day! When I installed windows xp service pack 3, my sound device was also formatted but I don't have my driver softwares installer for my panasonic cf-l2 lap top.. What should I do to have a sound...
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
you might have to get a portable usb sound card if you mean dont have a sound card installed
hope this helps
Feb 01, 2011 | Computers & Internet
No audio device or sound card on my lap top Toshiba
also
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers also
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 06, 2011 | Toshiba (4CH-VOUT) Sound Card
I have no volume on my vivicam 7025 video which i have recorded cannot play it back on lap top as there is no volume
The ViviCam 7025 does not record sound. You can add a soundtrack using video-editing software on a computer, but you can't record one on the camera.
I know that wasn't the answer you wanted to see, but there it is.
Dec 31, 2010 | Vivitar ViviCam 3915 Digital Camera
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
Hi i have an hp pavilion dv2000 lap top, i am trying to record my acoustic guitar into the comp. This lap has conexant high definition audio sound card inbuilt. However when i try and plug a microphone...
The mic may be muted on the computer. In XP, double click the volume control icon in the bottom right of the screen to get the mixer. If you don't see the microphone input, go to 'options' then 'properties' and place a check in the box to show it. Then make sure it is unmuted and the volume is up.
In Vista, right-click the volume icon and choose recording devices and make sure it is on and volume up.
Apr 23, 2008 | Computers & Internet
There is no sound
Download these drivers and all should be well :)
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=3&impid=-1&servicetag=&SystemID=INS_PNT_1501&hidos=WLH&hidlang=en
Hope that fixes it?
Jan 06, 2008 | Dell Latitude D600 Notebook
How do I turn my internal microphone on, please help
1)Double click on the speaker icon in the system tray to bring up windows volume control. 2)Go to options, then properties. 3)Select adjust volume for recording. 4)Make sure microphone is ticked. 5)Click ok. 6)Select the microphone in the windows volume control. Your microphone is now on. Just set the appropriate volume for the mic.
Aug 02, 2007 | HP Pavilion dv1000 Notebook
Dell Inspiron 2200 Notebook Logo
53 people viewed this question
Alun Cox
