Question about Maytag MMV5207A Microwave Oven
Blowing fuses The mwave is 2 months old. We just installed it a new Kitchen. We used this mwave about 2 weeks. The wife said it quit. I opened and checked and one of the 2 fuses blew. I replaced the fuse and it made a loud hum and blew the fuse again. Control panel and lights work ok untill fuse blows. I have been waiting 2 weeks for Maytag to get me service that doesnt seem to exist. Do you suspect t he diode or something else? Thank you
  • William Miller
    William Miller May 11, 2010
    Is it a model MMV5207A as it's posted under?
    Which fuse blew? I only see one in that model.
    When does it blow?
    If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
    If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
    If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
    The high voltage diode won't make the fuse blow.
    Once I get more details, I may be able to narrow it down (for academic purposes, of course) but any unauthorized repair attempt will void the warranty.
    I hope they get the servicer out soon for you but feel free to clarify here.
  • Maytag Master
  • 9,098 Answers
[double post]
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
But I would wait until the authorized servicer gets there (or take it to them) to maintain your warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
While in use my microwave shut off and stopped working. Could it be a fuse? If it is a fuse where would it be located.
mwaves shut off when they overheat and take a time to recover. This is a failsafe to prevent fire.make sure the unit has plenty of airflow around it and the vents are not blocked off ( hutches are notorious for overheating Mwaves) Sometimes the steam from a potato or a cup of water will overheat the sensor and cause it to shut down.
If it is a fuse the whole outer case hasd to be removed and it's usua;;y top left or right on the inner pod.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | GE Advantium SCA2000B Microwave Oven
No power no lights
There is a fuse inside of it near the power supply usually around the electrical cord, and it might have blown out if the outlet you plugged it into was not properly grounded.
Apr 20, 2010 | Rival Microwave Ovens
My microwave XL1800 keeps blowing fuses
Now this is not quite clear enough to give an accurate single answer.
Is it the fuse within the microwave or the general house supply fuse that blows?
If its the latter then an electrician needs to create a separate fuse line to reduce the overall load on the fuse, 15amps generally. Many houses have too many plugs being used at once on the same circuit TV, dishwasher, fridge/freezer, electric jug etc all drawing power. Big screen Tv's are the worst offenders.
If it is the fuse within the Mwave, then it needs attention,as a short has developed in the unit and needs to be corrected.
I will assume it is less likely to be this and punt for the first solution ( House fuse box overload)
Please rate my help++++Thanks for using FIXYA
Feb 13, 2010 | GE XL1800 1100 Watts Microwave Oven
Im looking for fuse replacement, where can i buy one ty
Fuses for Microwaves SHOULD be available from most reasonable size electrical stores. I suggest you open the Mwave first and remove the old one as a sample as many are not straight glass fuses but block ceramic ones usually around 25-30 amps.
Nov 30, 2009 | Sharp Microwave Ovens
remove cover of microwave, find and check the fuse
Feb 05, 2009 | Microwave Ovens
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
My Emerson MW8115FS 1450 Watts
hi your door has hooks which activate of the switches is called the monitor switch .the purpose of this switch is to close the mwave circuit[complete the circuit] indicating your mwave is safe for present your mwave circuit is open therefore your functions arenot working .check if door hooks are making contact with the switch ,check if the swith is testing continuity.ihope ihave been of assistance let me know cheers
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Maytag MMV5207A Microwave Oven Logo
234 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
