Router Tech Support Phone Number +1-844-456-4180. <a href="https://router24x7.com/"> Belkin Range Extender Won Connect to Internet Belkin Range
</a> as a company was the first in its field to launch a wireless router to share a single internet connection with multiple devices.
I'm not sure what do you mean by "your rj45". If it's a model of a router, maybe you mean that you can't get connected you smartphone to the router?
Are you sure SETTING of your phone is activated?
With setting activated, take your phone to a hotspot - site where you have free Internet connection.
If still can't connect it, probably the WiFi adapter circuit (well, anything like that) of your cell phone is failing. an you shouls check it with an authorized repair service.
Ok, that's my idea. Actually you can input a google search for
SMARTPHONE WON'T CONNECT TO INTERNET and you'll get sume return like these, to make an idea about issue
try to put your router back to its default factory settings, by pressing the reset button, usually found at the back of the router. whats the make and model of your router?
How many wired and wireless computers do you have ion the network. Do you have any wired computer ? Connect your laptop to the router with the Ethernet cable and try to access Internet. See if the wired connection is working or not. If the wired connection is working then I think you will need to check the wireless settings of the router and the laptop.
Are you trying to run the CD to setup your router? You can setup your router manually also. Connect the computer to the router and modem to the router. Change the Internet connection settings on the router according to your Internet service provider. Read Linksys router setup
1. have you connected the Netbook physically to the router 2. Is the netbook listed in the router as wireless device ( allowed to connect wirelessly.\ 3. if the device allowed to connect via the firewall. 4. Have you read the Netbook manual to connect wireless to a allow connection in your area. ************************************************************************* 1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox) 2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window) 3.Note router name you are connecting to. 4.. Check the laptop/desktop do ipconfig /all to see current IP addresses. 5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser. 6.Note router name you are connecting to. 7. Move the laptop about 20ft away and try to log on to the internet. This is for all routers to set up wirelessly. 8. check for firmware update at the manufacturers site for your model router
The wireless adapter in your ENGENIUS has connected to a wireless-router.
Depending on which router that has responded, the IP-address assigned by the router could be:
* 192.168.0.xxx
* 192.168.1.yyy
* 192.168.2.zzz
* 172.16.aaa.bbb
If the router to which the ENGENIUS has "associated" has _NO_ Internet connection, then you won't be able to access any web-sites.
You need to "dis-associate" from that router, and "associate" to a different router (one that DOES have an Internet connection).
