Computer won't boot
My dell computer won't boot up it keeps on saying Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM. I have try everything but I still can't get it to work. I tried with the recovery cd, but it doesn't work. Ireally need help, what do I do, someone help please.
  • jcgirl86 Jul 03, 2008
    I did that, but it doesn't work.
    Genius:
  • 2,785 Answers
Plz put the operating system cd in the room and follow the instruction
Posted on Jul 02, 2008
    Problem Solver:
  • 13 Answers
If that problems I suggest you to reformat your computer just back up the important files so that you can proceed to reinstall your system...Thats would be the last option for you....
Windows Xp won't start
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to useWindows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Feb 17, 2013 | Dell Dimension 2400 PC Desktop
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Jul 16, 2011 | Dell Latitude D810 PC Notebook
My computer wont boot windows but say's: windows could not start because the following file is missing or corrupt ;windowssystem32configsystem. What can I do?
Boot to you XP CD< press R for recovery console, run CHKDSK /R see if that resolves.
If not, hold Fn While powering on the system and run diagnostics the Hard Drive might be failing
Jul 27, 2010 | Dell Inspiron 1501 Notebook
It keeps saying that ntoskrn1.exe is missing
It is pretty much crashed....hard. Might want to reload the OS. Yes you can recover from that, but it is not worth the time and frustration to do it...Provided you can afford to lose whatever you had on the primary partition (C:\) drive. Let me know if you need other asst. It is a little complicated to explain. How many machines is this affecting? All of your E-Machines?
Aug 13, 2009 | Computers & Internet
Computer
Get the discs that came with your computer and boot off them. When your computer is on the dell screen when you first turn it on it will say something like "hit f3 for boot menu". You need to hit the button it specifies and select your cd drive. It will say press any key to boot from cd, and as you may have already guessed you want to hit any key. Then when a windows screen comes on you need to hit r and follow the onscreen instructions from there.
Apr 05, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
OS Loader v4.01
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
ACER DESKTOP COMPUTER
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
best regards wish u give me a good rate ^^
Aug 15, 2008 | Acer Computers & Internet
jasbo
jasbo
