Question about Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White
Electrolux Slide In Electric Range doesn't fit to the wall?
I bought the slide in range and it is away from the wall about 2 inches. I am having granite installed soon and need to know if the range is supposed to be flush with the wall or is it suppored to be out from the wall.
Do I need to have the granite cut to go behind the stove? It doesn't look right. Our installer put a plug on the stove. Do we need to cut a hole in the wall and take out the plug and hard wire the unit into the electricity. Elaine
  • ezeepaps Nov 19, 2008
    Thanks for your help. Your nswer is exactly what we did to install the range. It is lovely and I have a small 30 inch piece of Granite behind the stove. Your answer was appropriate, but I just got the answer today, Nov 19, my question was posted in July. The answers should come faster if they are to be useful. Thanks again. Elaine
  • jackntomsmom Mar 04, 2010
    Our freestanding electric electrolux range won't unlock. Our babysitter tried to start a cleaning cycle, when I came home it wouldn't unlock.
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Posted on Nov 30, 2008
  • 26 Answers
The range will be set out about 2 inches from the wall when properly installed. Don't change your plug-in, or cut holes in your wall. A quick search on the web will show you some options for "rear filler kits", if that is what you want. But the most attractive solution is to have a 30-inch piece of matching granite installed at the rear gap. A very narrow, nearly invisible grout-line will join the other sections of granite to the filler section. A custom continuous cut-out may result in a weak spot, subject to cracking or checking due to impact or hot-cold expansion-contraction. You bought the right range, you're getting the right counter-top....don't mess it up by sliding your range back to the wall....lol
mike
Posted on Nov 19, 2008
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    What does E15 fault in a electrolux stove mean?
    Thank you for your inquiry, friend!
    I understand that you are looking for the meaning of "E15" on your Electrolux range. "E15" stands for ESEC self-test failed, which could either mean and issue within your UIB (User Interface Board) or relay board. I would recommend having a professional come out to diagnose and repair your appliance. Best of luck. -Matt
    Aug 19, 2014 | Electrolux 30 Inch Black 30" Electric...
    Diagram electrolux
    Thank you for your post, friend!
    From my understanding you are searching for a diagram of your Electrolux range. I have located the manuals and diagrams for your appliance. I hope this helps. -Matt
    Frigidaire Manual Search Results
    Aug 19, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
    Electrolux Slide in Range will not go into self clean mode because of faulty switch
    Hello Iciapponi - From what you are describing it sounds like the switch that you are referring to is the motor latch assembly or thermal switch. Either or will need replacing in order the self clean mode function correctly. At this point, I highly recommend consulting a professional to accurately diagnosis the unit and to assist with the repair(s).
    Feb 25, 2013 | Electrolux EW30ES65GS 30" Slide-in...
    A mouse is moving white cotton like material from under the range top out the ventilation vents. how do i get the range top up? Unscrew two screws holding it in place? Also, how do i move the stove away...
    just lift the whole assembly from the front it will kind of lift up like the hood of your car.(most models)as far as moving it out from the wall it should have at least a foot or 2 of give slide it straight out from the wall if it is gas be careful not to break the flexible line if electric it should have a big plug like your dryer.
    Apr 25, 2011 | Whirlpool RF378 Electric Kitchen Range
    Maintop Filler Kit for GE slide-in range JSP42SNSS
    Maintop Filler Kit for GE slide-in range JSP42SNSS was missing. I am not sure why your response to a simple question (in a form of a question/offer to sign up for Premium Assistance Plan) referred to a different model number for a gas kitchen range (mine is electric!).
    I fixed it myself. I bought a piece of 2"x2" sheet metal angle, painted it black and attached it to the wall behind the range to close the gap.
    No need to bother your "Elite Experts" and pay $19.99.
    Aug 28, 2009 | GE Profile JGS968SHSS Gas Kitchen Range
    Unable to install the electrolux slide in electric range
    • Electrolux may have supplied generic installation instructions, failing to account for design differences
    • Electrolux failed to validate the installation instructions against the actual hardware
    Jun 23, 2017 | Electrolux EW30ES65GS 30" Slide-in...
    Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Logo
    4,337 people viewed this question
    Top Electrolux Kitchen Ranges Experts
    Craig Butler
    Craig Butler
    Robert Plante
    Andrew Taylor
    Andrew Taylor
    Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
