Question about E-Machines eMachines Desktop PC
Programs don't work
When I try to go into any of my programs on icons or the start list it just want go. It looks like it trying to do somthing but doesn't do it. It will go to a few but not many. My computer is very slow but it shouldn't be because I cleaned it out.
    President:
  • 173 Answers
If you have a lot of music files, pictures, large files, etc on your hard drive this will slow down your computer. If you have a good antivirus program you need to run it, because your system could be infected with a worm or virus. You might also want to look at how much RAM you have in your system and upgrade to more if you have any open slots for the modules on your motherboard. If you have a cd/dvd burner, burn those large files onto it I mentioned then delete them from your hard drive > use scan disk to check for errors and automatically fix them > then once that is done defrag your hard drive > Use msconfig in the run box, then go to your start up tab, uncheck anything that you do not absolutely need because when you start your system there are tons of programs running in the background and this takes up system resources. By unchecking them they will not automatically start running when you power your system on. Hope this helps and let me know if you need further assistance.
Posted on Jul 04, 2008
Belkin f5d8635-4a N+ router - autosetup won't work with windows 7 32bit
Are you running the autosetup program from a cd?
Click the start menu
Click the Computer icon on the right
Locate the optical drive icon under Removable Storage (it will probably be labelled Belkin)
Click the icon with the right mouse button and select Open from the list that appears
Now look for an icon labelled setup or something that has a belkin logo or something similar.
Click the icon with the right mouse button and select Run as Administrator from the list that appears. (if you cant find run as administrator then it is the wrong icon, try another.)
Does it work now?
If not, do you have a friend with a laptop that is running XP or Vista that you could borrow just to run the setup?
Dec 21, 2013 | Belkin N1 Vision Router
I installed my lexmark 2600 printer and there is no icon on my desktop screen, help
Maybe you have to reboot to get it on the desktop. Does the printer work if you opened a document and tried to print to it? If not, reinstall it.
Is it in your program list? Click Start/Programs or Start/All Programs and look for the Lexmark Folder. If it is there, then you can Right Click on any item inside the folder and select Send To/Desktop (Create Shortcut) to send it to the desktop.
May 20, 2012 | Computers & Internet
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 11, 2012 | E-Machines M5312 Notebook
As a Birthday Present I purchased a DVH-A85 Camera: The Supporting Software is a Arcsoft Program: No Version Listed: Tried a Number of Times to load this Program unto a recently purchased Packard Bell...
Welcome to Fixya. You can try to run a compatibility on the software and see if this will run on your computer. Install the program then on the icon on your desktop can you please Right Click on the icon then click on Properties. Click on the Compatibility Tab, Put a check on run this on compatibility then select Windows Xp Sp2 and see if this will fix the issue. If this wont work it only means that Windows 7 is not supporting the software.
Thanks
Jul 20, 2011 | Arcsoft Computers & Internet
I did something to my pc now all my programs have the extension .ink and i cant run anything or open anything what can i do?
The .ink files are shortcuts. If they have no icon, or the same icon then you deleted the programs. Try reinstalling them. If not, don't worry, just launch you application by double clicking the .ink files. If it doesn't work no worries, that's not a biggie and can be easily fixed in a couple of minutes. There are a couple of ways to do it, read both:
Option 1:
- Go to Start -> "Control Panel" -> Click on Porgrams
- Click on "Default Programs"
- Click on "Associate a file type or protocol with a program." to open the "Set Associations" menu.
- Scroll through the list of extensions to locate the .lnk file extension. The listing will show the description and the current default program associated with it.
- Click on the extension (to select it) and then click on "Change Program."
- Select the program you would like to open *.lnk file types.
- Click on OK.
Option 2 (If Option1 fails):
Simply download following file, unzip it, and run it. It will make necessary changes to the registry. Restart the computer and it should be fine.
http://www.winhelponline.com/fileasso/lnkfix_vista.zip
Jun 17, 2011 | Microsoft Computers & Internet
I cant find a icon on my loptop for the web cam what can i do to get it on
The web cam software should have a listing in you "all programs" folder off the start menu.
click on start, program files or all programs and look in that list for your webcam make name. If you find the program icon, you can left click on it and look for "send", click on send and chose place shortcut on the desktop. Then you won't have to look for it next time.
Mar 16, 2010 | Computers & Internet
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
How many days you working in you laptop befor coming the blue screen? -- many days, 2 days. or 3 days, then comes blue screen?..
if the blue screen come few days working.. 1) check the programs anti virus.. maybe infected of virus or programs adware.. if yo always connected to the internet posseble happen this case.. or maybe you insert somthing in your system.. like usb flash, mmc. or any device.. be carefall sometime the computer making blue screen if some system error. even you didn't see error before... 2. try make restore system if can.. just go to Start, program., accessories, system tools then, system restor..
May 31, 2009 | Asus Eee Pc 701Sd Notebook
No directions came with the computer.What do I need to know?.Some of the icons I have never seen.Help please joan cummins
have you tried to go to the manufacturer's website to download the manuals?
right click your mouse over the icon and see what the program is.
or you can go to start settings control panel add/remove programs and see the list of installed software. (most installed programs have icons, others, such as java, won't).
double click any icon and the particular program will start. click on the red X in the upper right corner to close any program.
Dec 02, 2008 | Acer Computers & Internet
Printer "out of memory"
a reasonable fix for microsoft is for you to spend $40
Aug 15, 2008 | HP Photosmart 4180 All-in-One Printer
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
