plz check your sound setting.for that instructions are: 1. go to your phone's "setting". 2. enter into "sound". 3. "ok" or "click" on "vibrate". 4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
This most likely has to do with the sound profile that you currently have set. Go into the sound options, see if there is a detailed option available to increase/decrease the ring volume or vibration.
Some phones have the option to turn on an alert and vibration for text/incoming call.s
Hello. There is a ''profile'' menu in your phone. Go for it. Select the profile you want to activate. Then select ''personalise'' option. Make the settings you want in it and then after saving it, select ''activate'' . Thanks.
hi there, You need to set the message center number correctly contact your operator helpline or try deleting the messages in your outbox and saved items.
Want to clear out info on your Sidekick info (ie: to sell yours)?
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device. To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit
will vibrate when reset. You can use a paper clip or similiar to hit
the reset button located behind the screen.
SK3 - remove the battery while the device is on.
6) Call your carrier and ask them to detach your device IMEI from the
username locked in. Once that is done, hard reset without your SIM card
inserted.
Get to the emergency call screen then hold down the Menu button (the one with the 3 lines), shift button and the letter Q at the same time for about five seconds and let it go. It will probably not happen the first time but do the same steps as mentioned again. Once you let it go the phone will ask if you are sure you want to completely reset the phone scroll to yes and hit ok. If you do not want to lose any stored data then this is not the method for you all data, contacts, etc. will be deleted. This worked for the Tmobile sidekick II Hiptop.
