Question about Teac SL-D80 Clock Radio
TEAC SD-L80 How do I set the time?  There is a time button but what do you do from there?
ON THE SIDE OF THE RADIO
Leave the slider in the"OFF" position. Press and HOLD the "Clock Adjust" button.
The light on the front of the radio should be blinking while you hold the button down.
While holding the button down......
To adjust hours: Press the ">>" button on the front of the radio
To adjust the minutes: Press the "<<" button on the front of the radio.
That is all there is too it.
Posted on Oct 26, 2008
How do you stop the clock when resetting the time? it will also not go into cd mode, but the radio works?
Posted on Jul 24, 2011
My 83 mother wants me to set time on her Teac 180 alarm clock?
Hello Hellen Barnett
The "time / set" button is the key to success...
(observe & restore the "lock/run" status when finished)
I could not find your SPECIFIC manual...
but I take strength in the knowledge that once
TEAC has a good design they generally stay in that area.
Take a look at the TEAC CRX188R owner's manual below
Location of Controls (Pages 4 & 5)
Teac CRX188R User Manual Page 4
Teac CRX188R User Manual Page 5
Carnac the Magnificent
Apr 02, 2017 | Teac Audio Players & Recorders
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
How to set clock on the teac sr-l100 just bought at yard sale, no info book. thanks d
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps!
To set the alarm on the TEAC SLR 100:
Be sure the radio is set to off or standby.
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
May 28, 2011 | Teac SRL50 Clock Radio
How do you set the clock
This is on page 23 of the manual for your device... This is the web link...
http://www.teac.com/resources/pdf/mc-dx32i/MCDX32_B_OM.pdf
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
Mar 12, 2011 | Teac MC-DX32i Shelf System
Comes up with format then check sd card
I've had this problem too.
Your Samsung Digimax L80 accepts SD Card cards.The largest SD Card card you can use in your Samsung Digimax L80 is 2GB anything larger and it doesn't work.
Jun 03, 2010 | Samsung Digimax L80 Digital Camera
Need to reset the date and time.
press the dataregistration button,press set,use the arrows to scroll down to usersettings,press set again,time&date will be displayed,press set and change the date and time.
Jun 02, 2009 | Canon FAXPHONE L80 Laser
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
Mar 23, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
May 26, 2008 | Teac SRL50 Clock Radio
Resetting the time on a teac mc dx321
In Power Off state hold down the TIME SET button. It will show 12/24 hour mode, then pressTIME SET again to set the hour and minute The >>| increments the time, |<< decrements - REDICULUS!
Apr 03, 2008 | Teac Audio Players & Recorders
Teac SL-D80 Clock Radio Logo
587 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
