Disconnected master Maxtor 60 gig and slave WD 200gig. reconnected and will not load. shows "no operating system found" on screen. Maxtor has 9 jumper pins..WD has 10. I'm baffled.
    Genius:
  • 2,785 Answers
If possible put both the hard drive in two different slot
Posted on Jul 02, 2008
Maxtor n256 60 gb HDD jumper settings
Here take a look at this pdf:
eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
So If this is layout " : : : . : "
then...
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 04, 2012 | Maxtor Computers & Internet
Take a look at this pdf:
then...
slave -----------
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
How do you pin a maxtor 40 gig hard drive? I want toi jumper it so it runs continuus withe the 40 gig hard drive I have with a operating system or how do I have two operating systems in the same computer I...
If you are using the older style hard drive, the main drive will be the master and the other the slave. The master has the pin up and down in the middle position and the slave should be the second to the last on the right when looking at it from the back. There should also be a diagram on the top of it. Double check me though, just going by memory. I know you are aware but.....make sure the computer is off and don't forget to plug in the power plug. The computer should "find" it on boot up and give it a name, probably D or E.
Nov 19, 2009 | Computers & Internet
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Jumper setting
Put the jumper on J50(the closest set of pins to the IDE connector)
This will set the drive to master, with no pins on it's currently set to slave.
Chris
Oct 21, 2008 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
Maxtor 60 gigabyte
which os ur usin??mac win?? try making it slave and then c and do run consistency chk
May 20, 2008 | Maxtor Hard Drive
New Maxtor SATA drive into computer with OS on IDE drive?
try to change your master as the 300gig then secondary master 40gig then your slave 20gig. then check it to the bios
Dec 20, 2007 | IBM (02R4087) Motherboard
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
