Question about Magellan RoadMate 800 GPS Receiver
Roadmate 800 has a white screen with no image
I have had this for about a year. last week it pwoered off and when i turned it back on the screen was white with no info on it. you can still hear that the buttons are working but can't see any thing????
  • Mike Kojis May 11, 2010
    I have the same problem. It must be common. Let me know if you find anything and I will do the same
    Mike
I opened the unit up, removed the covers and disconnected the ribbon that goes from the main board to the lcd screen, cleaned it and then reinstalled it. i then put the unit back together and it has been working fine for about 2 months. let me know if it works for you too!! good luck. dave
Posted on Nov 07, 2008
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My roadmate 800 will not turn on. When I use the reset switch, it goes to the blue "Logo" screen then nothing.
if its freezing on the magellan screen, there is a special utility from magellan to fix this issue. fortunately i havent had to use it yet so use caution while installing.
you can get the utility HERE
let me know if you need further help.
bill
Nov 14, 2009 | Magellan RoadMate 800 GPS Receiver
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Frozen screen
I have a Solution for this Problem,
i have a Software
Any need this contactme i don't know how to post the file,
Fabian
Apr 25, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Apr 02, 2008 | Magellan RoadMate 800 GPS Receiver
Need replacement LCD for my GPS
Call 407 212-6900 GPSINUSA.COM quick turn around 3 days, great prices, great service.
Oct 21, 2007 | Magellan RoadMate 2200T GPS Receiver
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
The screen images are in reverse
For clarification: You turn on your unit, the blue magellan logo appears clearly, but then the screen slowly starts turning white. Turning the unit off/on fixes the white but images are in reverse. CAUTION: It would help if you were grounded in some way prior to proceeding. Also, of course do this at your own risk. Make sure the cable going from the main board to the LCD is making a solid connection: 1. Take screws out of rear housing 2. Slightly seperate the rear/front housing 3. Disconnect the RF cable attached on the corner of the main board. 4. Pull off (or locate if they already fell off) 4 O rings from the screw mounts. 5. Fold over mainboard ontop of rear housing 6. Use fingernail or tweezers to lift up the plastic locking mechanism that attaches your LCD to the backside of your mainboard. 7. Pull out LCD cable, inspect for "gunk" on conacts (clean if necessary) 8. Shove cable back into slot on mainboard 9. Press down locking mechanism 10. fold mainboard back over 11. Put 4 O rings back on screw mounts 12. PLUG RF CABLE BACK IN! (signal will be zero if this doesn't happen) 13. Fit together front/back and screw back in.
Mar 22, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 800 GPS Receiver Logo
171 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
