Question about Kodak EASYSHARE 5100 All-In-One Printer
I put both a new blk ink cartitdge and color cartridge in and I keep getting a message to replace the color ink cartridge
I have replaced it several times and this is the first time I have had this problem...what do I do?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Run the head alignment and cleaning option
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
http://www.youtube.com/watch?v=RTFOBtdthAc
Good luck
www.inkjet411.com
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
Printer flashes error "replace color cartridge"
Try unplugging the machine and removing all the ink cartridges.
Now plug the power back in. Wait a minute or two and then reinsert the ink cartridges.
If you get the same message, the machine's ink sensors are probably finished.
Thanks,
Pat
Nov 08, 2010 | HP PhotoSmart 1115 InkJet Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Trying to put back in the color ink cartridge for 6210
The printers are bad about damaging the ribbon cable inside the print cartridge when you replace the ink cartridge. There is a small wire spring that gets pushed through the cable rendering the printer useless. Poor design by HP. How do I know? I did it to mine. It's cheaper to buy a new one then to have it repaired.
Jul 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Canon MP500 error message
If you're using Canon OEM (branded) cartridges you're going to need to ID the problem chip/cartridge so I'd try and get hold of some empty originals from somewhere (CartridgeWorld or similar perhaps?) and put those in as replacements for one cartridge at a time until you ID the problem cartridge/chip
If they're non-branded then chances are you do have more than one of the same chip but the solution is much the same...
If all else fails, take the printer to a friendly retailer who sell Canons and ask them to help you ID the problem cartridge.
Jan 19, 2009 | Canon Pixma MP500 All-In-One InkJet...
USB001
Aligning the cartridge has nothing to do with the problem of the u150 error that two of the same ink tank cartridges are installed. It's a defective chip in the ink cartridge, as soon as I placed a new cartridge in it worked like a charm. HOLD ON TO YOUR INK CARTRIDGE RECEIPTS, because if this happens to you and the cartridge is obviously new....the store of purchase should provide you with a replacement (+ if you don't want to make a 2nd trip, some stores have the mp830 on display and you can have them toss the cartridge in and check to make sure the chip is working properly). IF THE STORE WON'T REPLACE THE DEFECTIVE CARTRIDGE, contact CANON (USA 1-800-828-4040)and explain the problem & hopefully the will stand behind their product and replace the defective cartridge.
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
57 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
