Question about Refrigerators
Frigidaire FRS23HF5A side by side
When freezer door is opened, the circuit board for the water, ice dispense and the light for the same looses power. When the door is closed, the dispense light, the crush and cube lights come on, and the water condition light goes red. WHY?
  • 3 Answers
Check your ground from the door to the box at the top of the door. Run a small length of wire from the bolt of the main box to the door bold at the hinge on the top. This will ensure grounding of the door.
Other possibility is the ribbon cable from the dispensor to the power board. connection may be loose.
Posted on Nov 27, 2010
I have a Frigidaire model number PLHS67EESB9 side by side refrigerator. About 4 months, I has the water dispenser paddle replaced by a trained technician. Recently, the when the freezer door was opened...
Start by looking at the circuit boards for any sign of cracks or a trace coming off the board. Also, check all the ribbon wires for any signs of a break, corrosion, and so on. As soon as my database comes back online I will look to see if I have a service manual for that unit and any test procedures that you may do. Also, look at the door switch for any shorts or wire breakage. Post back any results to me.
Regards,
Richard
Oct 03, 2011 | Frigidaire FSC23F7D Side by Side...
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
Hi
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
http://www.ehow.com/how_6494535_troubleshoot-frigidaire-icemaker.html
http://www.ehow.com/how_6557721_troubleshoot-frigidaire-refrigerator-icemakers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire frs26r4a after opening and closing freezer door all panel lights are on - both cube and crushed ice panel indicators, and the light that illuminates the water and ice dispenser remains on until...
The only thing that I can see that would cause that is a broken freezer door light switch and possibly the power going through the adaptive defrost. Broken or fused to cause the power to come on when the door is closed...Click Here=> FRS26R4A I blieve i can help you with this if you are willing to work and communicate with me, Thanks Sea Breeze
Dec 25, 2010 | Frigidaire FRS26R4A Side by Side...
The water and ice dispenser stopped working, nothing on the control panel works at all
Looking over your wiring diagram I would go straight for the freezer door light switch. Part number 241547901 or 1037569 Switch-light lamp,freezer door. It is used as an interlock to disable the dispenser controls while the freezer door is open. I would unplug refrigerator and remove switch by prying out of its slot in the door frame. Use an ohm meter to test both ways. It has a three wire connection that while door is open lights are on and dispenser control disabled. When door shuts lights off and dispenser should have power. Let me know what you find, Thanks, Sea Breeze
Mar 19, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Oct 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Panel resets
Hi Tim, there was a service flash out on this model which has to do with the circuit board in the dispensor. Frigidaire has redesigned this board causing your problems. This should be covered under this service flash. The number of the service flash is 46-470. The solution is to replace the water filter and dispenser board. Contact Frigidaire and inquire about the service flash. Refers that were included in this flash have the serial numbers between LA113---- to LA146----. If yours fall into this range you should be covered. Circuit board kit number is 240533603. Your model is included in this flash...Catriver..post back.
Aug 21, 2006 | Frigidaire PLRS267ZAB Side by Side...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
