Yes you can use the trickle charge to keep the battery fit as it is stored up for such a long period. But at the same time the trick charging must be balanced or controlled not to over charge the battery . So if the charging unit has a cut off then it would be good as the battery will not be overcharged.
Hence you can try to get a good unit to keep your battery in trim condition.
