Question about Philips Magnavox TS3260C 32" TV
Is the cost of a picture tube really $787.00?
  • 4,234 Answers
Part number 483513127165 is the 32" CRT for your set and is available from tritronicsinc.com for $503.99 (plus shipping).
Dan
Posted on Jul 02, 2008
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
Where can i get a plasma picture tube n who put's them in for you,really ant got a clue bout plasma's also is it exspensive thankyou,samxx
No picture tube, just boards and a display panel---if panel turned out to be bad it costs more than the set did.
Mar 19, 2012 | Televison & Video
My picture is all scrunched up in the middle of the screen,black on the top and bottom,otherwise the width of the screen is fine! Is this a picture tube going bad or just an adjustment?
There's trouble in the set's vertical output circuit. Often this is because of bad solder connection, but there could be parts that need to be replaced as well. It isn't the picture tube going bad, though, so the set could be fixed. (Actually, even a bad picture tube can be replaced, but when the tube goes it's cheaper to buy a new TV!) Often just resoldering the connections in the affected area brings the picture back to full height. It's not unusual for capacitors in that area to wear out with age, but they're inexpensive parts.
The trouble with TV repairs is the labor cost. If you don't know anyone who has the skills to check over a circuit board and do electronic soldering, and to check and replace parts, you'll need to have a professional do it. The total cost of repairing a small TV might make it worth spending a little more on a new flat-screen LCD. They've really come down in price.
Most shops charge a fee (applied to the repair if you go ahead) to check the set and give a repair estimate. If you don't mind the gamble, get the set checked. Otherwise, start looking for a good sale on something new.
Jun 29, 2011 | RCA F27442 27" TV
My Sony wega triniton KV32FV27 has washed out color, low contrast/brightness. it was recently in the shop where they"rejuvenated the tube" and "adjusted the screendrives and focus". It...
The picture tube emission is dropping causing the picture to become washed out, the rejuvenating process removes build up of crud from the guns exposing more emission material, this improves quality in the overall picture. But since the picture tube was done a week ago it suggests the guns have been stripped of their remaining material and the picture tube will get progressively worse over time.
Feb 08, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Blue screen
u have bad blue picture tube , $300 - $500
Apr 15, 2010 | Sony KP-51WS500 51" Rear Projection...
My sony KP-65WS500 had a bad red picture tube. So
It was probably my post--SD TECH--you may want to tweek the red screen a little up or down--if it still acts up it is the picture tube--
The adjustment procedure is only meant to help and not cure the problem--try to get it as good as you can and live with it.
I have been involved with replacing those tubes and it is no picnic--you remove one--send it out for rebuild and put it back and do major adjustments--usual cost for rebuild is near 300 JUST FOR THE TUBE--real problem is that sooner or later the two other tubes will start to act up.
I composed those instructions to try to give people an option--to buy them some time--the picture tube is what some call a bulb--one in the same thing.
Lots of these sets had all three tubes changed when under warranty--what really happened is Sony put the wrong tubes in the sets to begin with.
My best advice is adjust it as best you can and when it goes replace the set.
Regards, SD TECH
Dec 19, 2009 | Sony KP-65WS500 65" Rear Projection...
I have a samsung hc-p4752w and I'd like to find out where I can get an inexpensive blue picture tube.
The blue tube will cost $150-$200 from a Samsung parts distributor. Keep watching Ebay. Did you change the coolant by any chance? The coolant fogs really bad on the blue tube on this model and it looks like a bad CRT.
Jun 17, 2009 | Samsung HC-P4752W 47" Rear Projection...
The image on my sony trinitron (model kv-32ts36) goes on and off.
BULB ? are you talking about the picture tube itself ? there is no bulb in your set that is replaceable like a DLP set if you need a picture tube your cost installed between 400.00 and 700.00 its a big job and i have not done one in years and years ,its just not worth the money . but if you really love the tv thats another story . i hope this helped . ...if this answer helped please rate a 4 or 5 stars , this high rateing will help keep me in the paid answer department
May 17, 2009 | Sony KV-32S20 32" TV
Picture has lines going across
No picture tube is cheap to replace. Especially a Sony tube. And besides the cost of the tube there's the labor cost to install it and some tedious adjusting needs to be done to set up the replacement. When a picture tube fails it's time to replace the set.
Now having said all that, there are different kinds of lines that can show on the screen. Some are because the tube is bad, but others can come from less expensive parts on the circuit board in the set. Without seeing the lines for myself I can't tell you about yours. If you are wanting to keep the set, I would suggest having a qualified shop check it. The can tell you for sure if it's the tube or not, and give you an estimate for the cost of repair.
Apr 18, 2009 | Zenith C27A24T 27" TV
Is this fixable??
Unfortunately, this sounds familiar. Many of these sony projections had bad crt's.(picture tubes). Now here is a secret I learned along the way. The short in the picture tubes is in the filament, causing that color to overpower all others and sometimes causing pix to disappear until set is shut off and back on. If you are very careful and use an insulated screwdriver, you can sometimes tap on neck of picture tube and knock debris from filament causing extended tube life. This is dangerous and must be performed with set turned on. From front of set gently tap on neck of tube(s) in question using insulated handle of screwdriver to make contact with picture tube neck. Picture will probably flash whichever color tube is contacted. Eventually, if picture stops flashing that color as much, you can sometimes get several more months out of your set without any problems. Only alternative is to try a crt rejuvinator or replace tubes at a cost of 200.00 each if avail. plus labor. Good luck, Russmann.
May 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Philips Magnavox TS3260C 32" TV Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
