Question about Acer Computers & Internet
How to install my ram memory of travelmate 272xv , i have one installed on bottom but another one i cant find it please help
    Genius:
  • 2,785 Answers
If you dont have any free slot for ram then you cant put a new one
Posted on Jul 02, 2008
    Problem Solver:
  • 13 Answers
If the other is already installed on your system try the other ram and because it is maybe damaged or the other ram is not supported by your PC..
How to fit memory in acer travelmate 6292
On this laptop you can use 2 G of ddr2 on 667 mhz ..If the size is not a must be ..and can be 1 G or 512 modules the speed need to be the one specified so to work without problems ..and also the type (ddr2 sodimm )
If you think this is eh case...Just open the lid for teh ram memory on the back ..and if teh slots are already having 2 modules..just remove one ..if it is smaller and use the 2 G one in its place ..Usually it came with 2 G of memory ..and if it is in one slot it will have one free but it can be in 2 modules one G each ..in this case it is even better cause you will have 3 G in total and you can avoid some of the troubles some found when using the max memory ..(boot up problems )
here is the procedure exactly in a video ...I suggest to reinstall teh operation system after upgrading for to work on full capacity and avoid issues that might appear ..(the system may not see the memory or have difficulties..But usually will work just with a restart or a bios reset to factory settings ..)
http://www.youtube.com/watch?v=EdjceQNzFSQ
This is for a different model but same kinda ddr2 modules ..and also a travelmate ..so the difference may be just in the cover ..but inside they are the same on the procedure ..remove the on eon top ..and install the 2 G module ..If it only have one module ..remove it ..to get to the bottom one ..and install the module and put the one you removed back in ..
good luck and please rate my answer ..
Dec 21, 2011 | Acer TravelMate 6292 Series Laptop Charger...
I have 512 K memory chip ,can I add this to my travelmate 6492
I do not know your specific model of laptop, but if the above specifications are accurate, then most likely not. Most laptops have two DIMM ports, where you place the RAM. This laptop probably has two 1gigabyte pieces already installed. This means to add yours, you must remove one and replace it, thereby decreasing your RAM to 1.5gigabyte total. Now under the rare possibility that your computer has a single 2 gigabyte RAM installed, then yes you can really easily. Just open up the panel on the back with the RAM inside and check. If only one is installed, then install the other (you can use google search to find the exact process), and your computer will be ready to go. I hope this helps, -Robert
Aug 26, 2010 | Acer TravelMate TM5720-6337 NoteBook,...
Hi can you tell me how much memory my 273xc will support and how easy it is to install thanks cj
Hi, the maximum memory you can install is 1GB of RAM...
to install, remove the battery first, then unscrew the screws at the corners of the bottom part of laptop then remove harddrive then insert the memory. ..
May 15, 2010 | Acer TravelMate 273XC Notebook
Install a new ram card
dude at the bottom of the laptop there will be small covers with a single phillips head screws in them under one of those covers is where the ram is located...
Mar 15, 2009 | Acer TravelMate 2300 Notebook
Can i upgrade
You wouldn't be voiding the warranty if you will buy the memory from Acer or ask them to walk you through installing it. You can call their tech support over the phone for assistance.
You have to know though that your laptop may just have two slots for the memory. That means you have to discard one or both the cards to install bigger RAM's.
Should you buy a non-Acer memory card, the warranty for the whole system should not be voided. But if the installation of the 3rd party memory card causes one of the parts of your computer to be defective, the warranty cant be used to replace that part.
Still, it's better to check the terms and conditions in their website. Just choose the warranty that you bought with the system here.
To be safe, better buy the memory from Acer or have them help you install it.
Dec 30, 2008 | Acer TravelMate 2300 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
MEMORY UPGRADE ON ACER TRAVELMATE 5720G
Acer's support isn't the best. IMHO But go to their support site anyway and look up your laptops manual (there should be instructions on upgrading your RAM there). I did find that your machine will accept up to 4GB of RAM 2 X 2GB sticks. There should be a door or port (for easy user RAM upgrading) that is being overlooked, but again it is an Acer.
Good luck.
Feb 23, 2008 | Acer TravelMate 2300 Notebook
RAM upgrade
that way it won't work you have to first remove your RAM and insert the new one and start it
Feb 17, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
