Question about Nokia 1110i Cellular Phone
Name of person not appearing when i get call from that person, even though the name and number of that person is stored in the phonebook...plz help
  • 1,010 Answers
Well its in the settings, go to menu-> settings-> (i think) call settings and it will be there an option to change it.
Posted on Jul 02, 2008
My motorola razr does not display the names when i receive text messages
check the phone book entries...possible the names are appearing twice in the phonebook...or the format in which nos are saved could be diff from the format of numbers u get message ...eg : u might have stores only no and when u recieve msg it might come with a 0 or country code too
Feb 11, 2012 | Motorola Mobility RAZR V3
I have entered a name in the phonebook and connected it to a tune so when that person rings the tune should play but it doesnt even though its all turned on and the tone has been confirmed whats wrong
When you entered the person into the phonebook on the phone, did you include the area code? It's wierd because it won't register who is calling if the phone number in the phonebook does not match exactly how it is coming in on the caller id. Try this, if it doesn't help let me know.
Nov 04, 2009 | Lands Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
When i recieve a text the persons name does not appear only the number comes
If you dont have them saved in your phonebook only the number will be shown. If you do have the number stored on the phone then double check the number and see if its in the right phone directory. Hope This Helps!
Jun 16, 2009 | Apple iPhone 3G
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
WHEN NAME AND NUMBER ARE STORED ON THE PHONE, WHEN YOU CALL SOME ONE YOU SEE THE NAME SHOWING, BUT WHEN THEY CALL, YOU ONLY SEE THE NUMBER OF THE PERSON AND NOT THE NAME LISTED IN THE PHONE. IF YOU SET THE...
This usually happens when you have duplicate entries in your phonebook.
Depending on the model of you phone, You can have only the phonebook or sim enabled but not both to avoid duplicate entries. Or it might be that there is really 2 or more Names for the certain number. Just review your phonebook and remove the duplicates. That should solve your problem.
Hope that helps.
Jan 07, 2009 | Motorola Mobility RAZR V3
Names won't display in inbox
Hi!
In my many years of using Nokia phones, I noticed that when there are duplicate entries on both SIM card and Phone memory, the names will not appear when they send you messages. You may try to check your phone and sim memory if the numbers are stored on both and delete the duplicate or choose just one memory to use, whether it be the SIM or phone memory to avoid conflicts.
Happy Holidays!
Dec 24, 2008 | Cell Phones
Motorola Problem
Thats not atall software prob buddy. You verify that your messages are saved on phone memory and that you are not using SIM stored numbers. You can surely backup all phone memory numbers to SIM by copying.
May 31, 2008 | Motorola Mobility W375 Cellular Phone
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Nokia 1110i Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
