Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Need a repair service
By jamieos on Jul 02, 2008
Saeco Aroma - won't pump and now won't switch on. Need a repair service within easy driving distance of Ridgefield, CT 06877
Same Problem
Feb 28, 2009
-   Seaco Incato Rondo S-Class I turn off the machine for cleaning and won't switch on. Is any solution offered to fix it Thanks-   Guest
Best Solution
posted on Jul 11, 2008
Very Helpful)
KaffeSumpen
Rank: Guru
Rating: 89%, 69 votes
A aroma is very easy to open up so if you can find a erpair station near you i would suggest you to fix it your self.
open it up and reset the fuses there is one on the top of the boiler when you open it up.
Then you need to prime it.
Turn it on ( as this should work now)
open up the steam valve and then press for making of a cup of coffe. this hould prime the machine though the steam nossle.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
kuerig b2003 has yellow & green lights on and red light flashing what's wrong with machine
Answer
Water is not coming out....just steam...must be plugged?
Answer
can't seem to get a hot cup of coffee.. only lukewarm. the knob where you choose - to + doesn't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
