Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Im not getting any spark from one of side of my 2 cyclinder kawasaki ninja 500 EX. Its an 1987. I have replaced the plug wires and the pickup coils. I switched the coil packs and both work. Im just not sure what else it could be.
  • Anonymous Sep 27, 2008
    I have the same problem with my 1987 Vulcan 1500 (88SE). After a cold start, for the first 10 minutes of operation the engine will fire on only one cylinder unless I pull the plug wire off and let it arc from about one-half inch away. (Needless to say, this is occasionally a shocking experience for me.) Eventually, it begins to fire normally and I can slip the cap back onto the plug. I have replaced the ignition coil assembly and plugs.
    Brigadier General:
  • 6,966 Answers
To my knowledge, a 1987 Kawasaki EX500 uses a TCBI with digital advance to fire the ignition coils upon receipt of pulse from the trigger/pickup coils.
Since the pickup coils are new, and you have swapped the ignition coild, replace the high tension wires and checked/replace the spark plugs, the the only cmponent left is the CDI (electronic ignition system).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 06, 2008
Kawasaki Ninja 250R will not rev past 5000 RPM
Hi, Tyler and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike not wanting to rev past 5k while driving ninjette org
Engine will not rev past 5000 rpm Ex 500 com The home of the Kawasaki...
Kawasaki Ninja 250R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Feb 23, 2017 | kawasaki Ninja 250R Motorcycles
WHAT IS THE SPARK PLUG ORDER FOR A KAWASAKI NINJA 900 1985
Left coil feeds 1 and 4...right coil feeds 2 and 3...as long as you stick to this it doesn't matter which lead goes to which plug. Left coil will have one short lead and one long...short =1...long = 4. Right coil leads will be about even in length...doesn't matter which goes to 2 or 3.
It's a wasted spark system so plugs 1 and 4 fire together...2 and 3 fire together...only 1 cylinder in each pair will be compressed and ready to fire when the spark happens, the other will be empty and coming on to it's inlet stroke...
Jul 20, 2014 | kawasaki Ninja 1000 Motorcycles
1987 kawasaki ninja 750r f1 not starting after running perfect 45 minutes ago
check that fues under the right side fairing its in a lil rubber thing that protects ur silonoid
Jun 28, 2013 | Motorcycles
Can not find the spark plugs on my 1998 kawasaki zx-6r ninja
take tank off,remove air box, and follow wire from coil to top of motor,pull up on spark plug wire,the spark plug is inside about 3 to 4"down inside of hole.
Feb 20, 2011 | 1998 kawasaki ZX-6R Ninja
How can i tell when my 2002 kawasaki ninja 500R needs a tune up?
Check the maintenance schedule in your owners manual or on www.ex-500.com. The 500 requires a valve adjustment and carb sync every 8000miles. Spark plugs should be checked and replaced, if fouled at the same time as the valve adjustment.
Nov 09, 2010 | kawasaki Cycling
I need to know the wiring order for installing the spark plug wires on my 1996 kawasaki ninja zx9r
should be like most 4cylinder bikes...left side coil #1 and #4 plugs right side #2 and #3 plugs. try it if it dont start, then i was wrong. but thats what is on my cbr.
May 04, 2010 | 1994 kawasaki ZX-9R Ninja
I tired to bypass the switch and put all the wires together lights came on and its turning over but im not getting any fire to the plugs ninja 500ex
You need the stock ignition switch in order for it to trigger a relay inside the igniter, then it will spark, this is part of Kawasaki's anti-tamper proof ignition system.
Apr 19, 2010 | 2002 kawasaki KX 500
I just picked up a1986 Ninja 1000.Sometimes it runs on all 4.But most of the time just 2I just checked and the right side coil has continuase power.What might cause such a thing? Please help Iv been at it...
Its definitely sounds like ignition parts or wiring... What parts did you replace on the ignition? I am not sure on the ninja 1000, but some of the Kawi's use 2 pulse (pickup) coils off the flywheel/magneto, You can do a simple Ohm test on these (if applicable).
You can also try swapping the HV coils around to eliminate those.
Then of course the ignition module, or CDI ...
I am sure you probably checked all your grounds and connections...
May 08, 2009 | 1986 kawasaki GPz 1000 RX
Lands Phones Logo
262 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
