Question about Panasonic Lumix DMC-FZ7 Digital Camera
Cannot take pictures
When I turn on the camera, the lens will not extend. there are five beeps and the message"remove lens cap and press>button" appears. Pressing the button does not solve the problem.
Please help, I will pay you.
David Taylor
Has the camera been bumped recently?
This could cause one or more lens elements to shift slightly out of position and thus prevent the lens from extending.
You can check inside the lens, and try to shift the lens elements back into position by bumping the camera the other way. I have read some people were actually successful at this.
(Don't bump it too hard).
If the lens still doesn't extend, then there are still some options:
1. Take or send the camera to a service center to get fixed. This will likely be over $100.
2. Get a new camera, there are better ones out there and for close the same price as having this one fixed.
Posted on Jul 12, 2008
Finepix gives message to turn off then on again. keeps foping it no matter what.
It may be your lens cap. If the lens cap is on, the lens cannot extend, so the camera will give you notice to turn the camera on and then off again (assuming you know that you must remove the lens cap before turning on again. If your lens cap is off, check to see if there is anything else blocking the lens or impeding it from extending.
Aug 27, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
When turn camera on get message turn camera off then turn camera on again. did that and repeatedly get same message.
Check to see if your lens cap is on. If the cap is on, the lens cannot extend and you will get that message. If your lens cap is off, check to see if there is something impeding the lens and keeping it from extending. Your camera may "think" the lens cap needs to be removed.
Jul 28, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
My camera has a "lens error". It will not contract back and stays out in beeps and gives me this message to start, but doesn't do anything.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
Jun 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
Camera beeps five times, doesn't work
the beeps mean the lens can't be opened or closed. maybe something stuck or it's just failed?
Aug 30, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Camera wont turn beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
105 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
