Question about HP Pavilion dv6000z Notebook
Wireless issue Dear Expert, I have a HP paviolion laptop with Vista installed, and a BELKIN wireless router in the office. i have assigned static IP for laptop on it's alternate IP for wireless connection because i use DHCP at home with it's Primary IP. however i have disabled DHCP from BELKIN router but still after every 15 to 20 minutes my wireless card starts searching for Automatic IP and then i have to repair the connection to reconnect to the router. please let me know with your kind support. Thx-AryaN
    Scholar:
  • 174 Answers
As far as your primary connection is DHCP and when its detects wireless conecction it will start getting to connect to the device becoz in you configuration you choose connect to any wireless access point option. At office your laptop try to connect but the secondary Ip address and primary configuration get conflict and primary configuration ask you to repair or shows limited connectivity option. Better is enable dhcp on you both sides so that you will not face any problems
Posted on Jul 02, 2008
How can I make settings to support DHCP IP assignments and also recognize my manual IP's assigned to the LAN connected devices?
The easiest way I can think of is to shrink the DHCP address pool.
To do that, at least on the model of Actiontec router I have, click on "Network (Home/Office)" the go to the "IP Address Distribution" section of the screen. "DHCP Server" should already be selected, and under that, you'll find "Start IP addresses" and "End IP addresses." Usually, the start will be 192.168.1.2 and the end will be 192.168.1.254. What I usually do is change the start address to 192.168.1.200. That leaves over 50 addresses for normal wireless connections, and I'll general assign IP addresses from the rest of the range as follows:
192.168.1.2 to 192.168.1.9: routers, APs, etc.
192.168.1.50 to 192.168.1.59: printers
192.168.1.100 to 192.168.1.109 for other static devices. (I often find that Blu-Ray players, cable boxes, etc. behave better if they have a static address.)
But really, on home network, I doubt you'll have more than 15 devices that need static addresses, so you could set the DHCP start address as low as 192.168.1.16 if you wanted to.
Sep 17, 2015 | Linksys Computers & Internet
How to setup a dmz
First , Assign a static IP address in the Device that you need to add in DMZ.
The IP address should be in the range 192.168.2.2 - 192.168.2.254
Click the link for instructions on How to Assign Static IP Address in Windows 7 8 XP or Vista
The Default Gateway and the Primary DNS should be 192.168.2.1
Once that is done.
Login to router Setup : http://192.168.2.1
Click DMZ under firewall
Leave the password blank and click submit
Enter the static IP you assigned
Click apply changes
And thats it, The device that has the static IP is now in the DMZ
Hope it helps
Regards
Rakesh Warrier
http://facebook.com/quietmouse89
Feb 12, 2015 | Belkin Wireless Play Router F7D4301
Not able to connect with the router in... no ip adress bieng pulled up...
If you are not getting Ip address from the router to the computer then you can assign a static IP to the computer.
If it is a wireless computer then you try to disconnect from the wireless network and reconnect to the network.
Click here for more info
Oct 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Problems with my Belkin N1 router since we have 1 PC on Vista
to solve this problem you need to set up static IPs on your LAN clients. Whether your SIP provides you with a static IP or not makes no diffrence you can still assign one to each machine on your network and that should solve the problem.
Jul 04, 2009 | Belkin (F5D5231-4) Router
Wireless connection problem
When you say "IP and DNS settings are correct", can you define what "correct" is? IP and DNS settings change depending on the wireless network they're using, so one setting will not work for all networks. The most "correct" setting you can have is probably DHCP - which is called "Obtain IP address automatically" and the same for DNS. If your laptop has any statically assigned IP information, make a note of what they are, and then change it to DHCP and see if you have better luck. If you have statically assigned IP information, it will allow you to connect to the wireless network, but not provide internet access because your IP scheme and DNS settings are wrong. It sounds like the scenario you're describing.
May 17, 2009 | Dell Inspiron 8000 Notebook
Configuring the wireless router
goto start>>
click run
type cmd
type ipconfig
check what is ur default gateway
then goto internet explorer
type the default gateway in address bar
YOUR belkin router homepage will come up
If it asks you for any username and password
U will have to contact belkin to get that...
after entering the username and password
u will be able to check the configuration setings
Use one of your static IP's instead of Using the dhcp server to assign them.
If this helps please be sure to rate it!!
Jan 13, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ps3 gaming timeout
try assigning static ip/sm/dg/dns on all wireless ps3
Jul 25, 2008 | Belkin Wireless-N Wireless Router with...
Router blocking my downloads
k i think why its happend probabally there is a port blocking is there in the belkin router so try this set static ip address on the pc in the range of belkin>and login to belkin router and enable DMZ on the belkin router the dmz host ip should be the one which u assigned statically on the pc
Oct 13, 2007 | MSI Wireless-G RG54G3 Router
HP Pavilion dv6000z Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
