Problem with Canon Color C3220 Copier - Color imageRUNNER C3220 Printer
Error code e000020-0181. all the drums were changed with new. error code e000020-0125 appear..
379 people viewed this problem
This solution has been voted best by the Fixya Commnunity
Welcome to Fixya
Error you provided means there is something wrong with the toner. Have you replaced the toners?
You may try this torubleshooting. Depress the Additional Function key, then the 2 & 8 keys at the
same time, and the additional function key again. This will display the service mode menu. Touch the Copier key. Across the top of the screen you should see " Function ". Touch it, look for CLEAR in the middle column. Touch it, then ERR, then OK. Turn off the copier and wait a few seconds then turn it back on.
Thank you for using Fixya!
I put in a new drum and the display is still saying ?Change drum soon?. How do I reset it?
I have an OKI C9800. After replacing the waste toner cartridge and cleaning the toner transfer belt. I reinstalled...
I have just changed the drum unit (black) as requested on the screen However, error code u28 keeps on flashing despite...
Yesterday I changed the drum and developer unit of the machine. The very last step involved performing an ATDC...
its looks like photo copy machine, and not to compare like that but it is. i felt to connect to the computer, thats...
My office is networked: 6 Macs and 1 PC. Everyone else can print using the network just fine. I replugged my ethernet...
Is it possible to have heavy paper just run straight through the printer and exit at the bottom slot?
edchun Thanks, This problem solved.
But another main problem about printed image.
After printing, very thin white line appear. it looks like scratch. Every image hase same this line exactly same position from top to bottom. Is it kind of dirt on lens? I replaced new fuser, new toners, and new drums. What is the problem and How to fix it? I'm doing in middle of project.
Ed
Dec 17, 2010
edchun Thanks, it works. I appreciate.
Dec 17, 2010
