Question about Cell Phones
I have bluetooth standard in my car. 2008 honda odyssey. when i try to make a call from my phone(blackberry curve) it doesn't connect right away and then when I finally get connected the person on the other line seems to have been waiting for me to say something for a bit... any help?
  • 1,010 Answers
Its sounds that you have no reception.
Well 2 things it could be:
1. your blue-tooth is not fit to your phone
2. your blue-tooth isn't installed right or the place you installed it is bad.
Posted on Jul 02, 2008
Blackberry curve just reboots doesnt turn on
Buddy Just Download Destop Manager Of Black berry and connect to pc and format every thing or upgrade the software it is because of any application ( Corrupted) Just try and replay
Nov 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
How blackberry bluetooth connect with other phones
Go to manage connections and bluetooth options, press menu key and select add device. Standard code for pairing is 0000, but you may use any code you like, but give it to other person. Then you can pair. You will not be able to receive any pics/tones, and such until you go to media, press menu key, and select receive using bluetooth. Then it will work.
Jan 15, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Connecting to bentley bluetooth
Try the default codes 1111, 0000, 1234. Make sure that your Bluetooth Headset is in pairing mode and that your Blackberry is set to on and is visible to all devices.
Dec 17, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
