Question about Canon ZR200 Mini DV Digital Camcorder
Canon ZR70 MC Mini Digital Video Camcorder...Not ejecting
I am not able to insert a tape because it is not fully ejecting. When I open/eject the outer part, it moves out, but then the flap doesn't open for you to be able to insert the tape. Please help! I'm having a baby next week and want to take video (not of the birth) of the baby's first day.
  • 1 more comment
  • jennohara1 Jul 02, 2008
    Thank you for your quick response. Yes it does make a motor noise when the well opens. It actually sounds normal except the flap doesn't open and then the well closes. Do you know if this is simple to have fixed from a professional?
  • stentqueen Dec 16, 2008
    I have the same problem with my
    Cannon ZR200 Mini DV. I took it to a camera shop and they said it needed to go to the repair shop as well. Thanks for trying to help.
  • Jian Zhang Feb 01, 2009
    Same problem, ZR 70, the well winding, then stopped, then it went back before opening up for tape. Do not know what to do about it.
  • 979 Answers
Typically, the problems of this sort tend to be one of a mechanical nature; In other words, the case may be bent, causing this problem. Does the machine make a "motor noise" as the well opens? And then makes a "binding noise" before coming to rest? This would be a definite cause for your dillema, and a camera shop visit would be in order, unless you have some mechanical aptitude....accordiaman
Posted on Jul 02, 2008
  • Michael Borelli Jul 02, 2008
    This is indeed a repairable item as the cost to "adjust" the mechanism is negligible. Be aware, though, that there are shops who will simply want to replace the carriage and be done with it, costing you about 3-5 times what the adjustment cost may be...accordianman
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Won't Eject Tape
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back.  I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,  we bought a flip video, it works.
Oct 06, 2008 | Canon ZR60 Mini DV Digital Camcorder
Re: Canon Digital Video Camcorder ZR70 MC DC 7.4V
hello,
As your camera only has analogue outputs, you will need to buy a video capture card for your PC, such as those made by Leadtek. As mentioned by Tela above, there are also external USB-connected devices that do the same job.
Make sure your PC exceeds the minimum spec or you may lose information during capture. I would recommend at least 1GHz processor.
Hope that helps.
Jul 31, 2017 | Canon ZR40 Mini DV Digital Camcorder
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Cassete willl not eject
Solutions * The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. * Once the power source is available, some models require manually unlatching and opening a cover. * When the cover is fully open, the cassette will eject automatically after a few seconds. * If the tape still will not eject, seek assistance from a Service Facility because you need a special tool to remove the tape without causing further damage.
Dec 13, 2006 | Canon MV850i Mini DV Digital Camcorder
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
240 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
