Only one of my subs are working after the install
  • 682 Answers
Confirm that you plug all cables in right place-confirm that no cable touch each other- reinstall your system again.
Posted on Jul 02, 2008
No bass from Bose AM 15 Sub
Sub will only work in surround mode, not stereo mode. Also source must have sub component (5.1, 7.1, 9.1 etc) If your system was transmitting sub signal before, be sure you have chosen a mode which includes a sub signal.
Nov 11, 2013 | Denon Audio Players & Recorders
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Just installed the sub it work for 10 sec then quit checked the amp and its working with a old sub do the subs freeze or something
The amp needs to "see" a load and if the new sub is incorrect the the amp will sense improper amps and will shut down, a protective circuit. Load the amp with the correct speaker....
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio & Video
Subwoofer not working
It should work but I think you have more problems.
Mar 08, 2008 | Televison & Video
Just stopped playing
is it a seald box or a ported box?
Oct 23, 2007 | Jl Audio 12W7 Car Subwoofer
14 people viewed this question
 Grubhead
Grubhead
