Question about Sharp SF 2020 Copier
Service Mode On Sharp SF2530
How do I enter service mode on a sharp SF2530 error code h5-01 displays at startup.
  • Anonymous Mar 22, 2014
    i have a sharp DX-C200 and its showing service call SC542. how do i enter SP mode to perform the 5810 proceedure?
  • Anonymous Mar 28, 2014
    fuser temperature adjust
  • 148 Answers
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
I have a sharp AR M256 we were getting an error toner replenishment in progress. CAll FOR SERVICE. CODE H4-21
sir
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Mar 09, 2015 | Sharp Office Equipment & Supplies
How to clear an service error code on a sharp printer?
try turning the machine off then on. if that doesn't work, from copy mode type # * C * to go into service mode (test: enter a simulation). Clear codes 14, 15, 16, 17. type the number then hit the start key. then CA to reboot, you must try the codes on at a time. Please report what your error code was.
May 29, 2014 | Sharp MX-3501N All-In-One Printer
Service code for sharp tv model 21F-PD250
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 10, 2012 | Sharp Televison & Video
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Dec 10, 2008 | Office Equipment & Supplies
Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
May 08, 2008 | Sharp AR-M237 Digital Copier
871 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
