Question about Whirlpool ED2FHGX Side by Side Refrigerator
NOT OPERATING... I now use this fridge as a garage/beer fridge. The power was lost for a few hours and now it won't cool. I have checked the fan, running. I have checked the compressor, don't know if it is running but it is hot. I even called Whirlpool. They told me to they would send out a Service Tech, they would cover parts, but not labor. When I asked about the labor charges they told me to call the Service Tech. The air blowing out of the vents is cool but nowhere near cold. Help me please.
  • 481 Answers
  •  i would first thoroughly clean the coils under the machine and make sure the airflow is not obstructed in any way.
  •  a hot compressor means 2 things,
  • either the compressor is going bad
  • or the heat is not being released by the coils fast enough.
  • another thing you can check is for frost buildup in the back of the freezer, this would be a defrost problem.
  • If so, it is not defrosting as it should.
    • possible causes:
    1. bad defrost timer
    2. bad defrost heater (in freezer)
    3. bad thermo switch in freezer
    If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jul 02, 2008
Bosch intelligent frost free 44
the fridge might have iced up in the coil due to a defrost problem. one way to check it is to leave the fridge off for a few hours and leave the door open. turn the fridge back on after the few hours and see if the performance is any better. Let me know how it goes
May 22, 2014 | Refrigerators
I have a 1999 Alero 3.4 V6 the cooling fans won't run. I checked the fans they both work if I unplug the harness for the temp sensor,the relays and fuses are fine,I replaced the coolant temp sensor and...
CHECK MODE RELAY IF BOTH RELAYS GOOD YOU CAN CHECK RELAY BY REMOVING IT FROM FUSE BOX HOOK RELAY TERMINAL 85 TO BATTERY POSITIVE AND GROUND TERMINAL 86 IF CLICKS RELAY GOOD. IF RELAY GETTING POWER GOOD AND THE 30 AMP COOLING FAN FUSE OKAY.EITHER THERE IS A SHORT IN COOLING FAN WIRING OR THE PCM HAS FAILED.THE PCM HAS LOST OR COMMAND RUN CIRCUIT IN PCM SHORTED OUT DUE TO PCM FAILURE.LET DEALERSHIP OR GARAGE USE DIAGNOSTIC EQUIPMENT TO ACTIVATE THE PCM SEE IF IT HAS FAILED.DONT SPEND MONEY ON NEW PCM COULD BE SHORT IN THE WIRING CIRCUIT
Sep 06, 2011 | 1999 Oldsmobile Alero
Frigidaire Fridge/freezer works then doesn't work???
every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
Sep 23, 2009 | Frigidaire Freezers
Not Cole -- fan inside are blowing room temperature air
If after freeing the fan blade it still will not turn, you have a bad fan motor. (almost certainly due to it being restricted.)
That will cetrtainly cause it not to cool properly.
If the fan will not turn after freeing it, it will need to be replaced. If it does turn properly, unplug the fridge for about an hour to let the compressor cool down. Make sure all the coils vents etc are free of dust and dirt. Plug it back in, and if the fan is still operating properly, you should be back down to temp in a few hours max.
Aug 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
My electrolux rm 2310 has stoped working (the beer is getting warm). When used in all 3 modes there is a strong smell of amonia. What do I need to do to fix this? What should it cost to fix?
Classicpark;
The cooling unit has lost it's ammonia/hydrogen. Need to replace cooling unit or entire fridge. Prices for repair are as follows.
Part# 2934334091 $ 482.67 New 2 hour install
Replacement fridge RM2354RB $844.00 1 Hour install The R means right hand door. If the is a left you will need an L hinge kit. $27.00 plus .5 hours install.
Rebuilt cooling unit $400.00 2 hour install
All prices do not include shipping.
I know someone that will supply you with what you need.
Post back and I will give you the link.
Thanks for using Fixya
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
Jul 02, 2008 | Amana Refrigerators
SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Dec 17, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Fridge not cooling
It might be that the fan motor somehow got disconnected or worn out, or that the fan itself is stuck.  It’s located in back of the freezer.  Gently unscrew the back and check it out.  You might also have to unscrew the thermostat housing if it is on the top of the fridge part.  If the fan is turning, it’s okay.  If not, turn the thermostat down to its lowest setting and see if it turns on.  If not, unplug it and test it with a continuity tester.  If, there’s no continuity it will need to be replaced.  Good luck.
Oct 13, 2007 | Refrigerators
Whirlpool ED2FHGX Side by Side Refrigerator Logo
50 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
