Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-40XBR800 serial# 9003511 help plz
Baby turned on/off button twice and now it doesn't come on at all. It is flashing it's signal. At times it is 6 flashes and at other times it is 7 flashes.
We tried un plugging and resetting but to no avail, we now have this tv in our living toom and we can see anything, can you assist? We are technically inclined people.
Thank you
    New Friend:
  • 84 Answers
YOU KNOW,SONY PRODUCTS ARE QUITE EXPENSIVE,SO DON`T HESITATE TO JUNK IT NOW AND BUY A NEW ONE.AND PUT IT TO THE PLACE WHRE MINORS CAN NOT BE ABLE TO REACH
Posted on Jul 02, 2008
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Sony kv-40xbr800 blinks two times
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Jun 09, 2012 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have a Sony kv-40xbr800. The standby light flashes 6-7 times and does not turn on. If left off for a couple of day, it may turn on. Is there an easy fix?
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Jun 05, 2010 | Televison & Video
I have a Trinitron KV-40XBR800. Won't come on.
the indicator lamp flashes a determined amount of times then there is a pause, then lights the same amount of times again, by what you describe there is a power supply or a deflection circuit problem.
Jul 28, 2009 | Sony Televison & Video
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony VEGA KV-40XBR800 d Board failure
sony kv-40xbr800.......doesn't turn on......standby light blinks 6 times....what might be the problem?....is it worth fixing?
Dec 27, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV 40XBR800 will not turn on
Likely to have two ic's bad....both are the same. Part number MCZ3001D. Located close to each other. Must be unsoldered and new put in. I have fixed several with this problem
Mar 15, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
