Question about Sega Genesis Console
Line across top of screen
I just got a practically new Sega Genesis off Ebay and it seems to go through phases. It displays a thin horizontal line across the top of the screen. This line isn't there all the time but it always gradually appears over time when I play a game, usually getting thicker. When I switch to another game it's still there. Sometimes it's already there when I first turn on the system after not playing it for a while. I don't know if this is a normal thing for a first generation Sega Genesis (1991 model that comes with Sonic 1) but it gets me wondering. Most people wouldn't care about it but I just would like to know if it's normal. I used to have a Sega Genesis years ago and I played it on rounded cornered and sided TVs that would hide the line if the line was normal, but now with a strait-cornered TV I can see it. Could you tell me anything about this line, if it's normal or not for a practically new (Very new really) Sega Genesis? Thank you.
-Don
  • 4 more comments
  • history1 Jul 02, 2008
    This is a United States Sega Genesis.
    Another comment about the line which would better clarify it is that the line is a color that changes as you go to different areas of a game. The color changes when the primary background color changes.
    Forget about this problem. Putting this problem on this site was a waste of time. I'm getting adjusted to the line and it isn't really bothering me anymore. I don't need a solution anymore. I'm sure it's normal for this model and version of this Sega Genesis. Sorry. No need for anyone to post a solution for this one.
  • history1 Jul 08, 2008
    Hello. Feel free to talk about this line.
  • history1 Jul 10, 2008
    Is there a way to eliminate the line? Is this common on strait-cornered TVs or most TVs including the ones back in Sega Genesis Days? Actually I'm still interested in this subject. Just wondering.
    The last comment was made after the solution, so it would be nice for it to be resolved. I am still interested in this line subject, and really wasn't entirely not bothered by it.
The line is actually part of an unseen border.
Posted on Jul 10, 2008
Balancer repair
Normally horizontal line [a thin vertical line across the center of the screen] fault with CRT based TVs is the fault with its vertical scan output section circuit. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 11, 2016 | Televison & Video
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
I have an old sega genesis and got new plugs to plug it into my 42'' HDMI Vizio. all the plugs are in and the light is on but the screen stays blank. I have tried blowing on the game and got the...
Did you say HDMI? I don't think there are HDMI plugs for Sega Genesis. You can plug in your Sega via composite video through RCA cables (yellow, red white) or via RF signal through coaxial cable. Check your TV's specs to make sure it can display standard definition content via composite or via RF.
You can double check to make sure your Sega Genesis is working properly by plugging it into an old-fashioned CRT (fat tube) television set.
Sep 02, 2011 | Sega Genesis Console
I recently plugged in my Sega Genesis (MK-1601) console and purchased A/V cords to hook to my tv. When I turn the power on (the red light goes on), I usually just get a flash across the screen and then a...
This is pretty common. The games just need a good Q-Tip cleaning, and then the weird clean pencil-eraser rubbing.
Get out a Q-Tip, and rub it inside the game, on the copper part (The part you stick down into the system.). Keep doing this with new Q-Tips if the old ones get soiled with black stuff. After the new Q-Tip comes out white, it should work.
Sometimes, that isn't enough. Use some Windex or any other rubbing alcohol, dip it onto a Q-Tip, and rub it onto the copper part. Then, use a dry Q-Tip to dry it off, and let it sit out of it's case and out of the system for about 20 minutes so that the alcohol dries.
If that doesn't work, use a pencil with a clean pink eraser at the tip. Rub it inside the game, and use a Q-Tip to get all of the eraser shavings out. This breaks the electro-static cling/friction made when the game is being read by the system.
And if none of that works, go on Amazon or Ebay or to the store Slackers and get new video and AC wires for the Genesis. Sometimes that's all it needs!
I really hope this helps!
Aug 05, 2010 | Sega Genesis Console
Sega genesis isnt working...
Have you cleaned the Sega? What I mean is where the casset game goes. Push down the little flap, and there should be a little strip with contacts on the inside. Just clean it with a cotton swab and alcohol. And also, clean all your games also the same way.
Hope this helps.
May 09, 2009 | Sega Genesis Console
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Jul 02, 2008 | Sega Genesis Console
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Thin black line across display screen on psp
yes unfortunately i think its been dropped by the sounds of things,and yes it can be repaired,you can purchase a screen off ebay thier not that expensive,if you know anybody thats electricly minded if so let me know and i'll send you the webpage that shows you how to do it step by step.dont send it away to be mended what ever you do because it'll cost more to repair than its worth.
Jan 26, 2008 | Sony PlayStation Portable (PSP) Console
Sega Genesis Console Logo
183 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
