When moving from editing to share in video studio 10 plus, a warning box comes up ' type face cataneo BT not found ' if i git pass this and click on burn another box appears ' convert step got some problems ' and i cannot go further.
  • prayag_78
    prayag_78 May 11, 2010
    you are trying it on which program eg windows movie editor or what??
  • 92 Answers
There Is A File Missing. Reinstall Video Studio 10 plus.
Posted on Jul 02, 2008
TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
Please perform the below steps to fix the issue:
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Oct 04, 2010 | Computers & Internet
Tip
How to convert MVI to AVI file for edit in Pinnacle Studio?
Some Canon digital still cameras (Powershot A75, A63, S410 etc), are capable of shooting a limited amount of video, since there is no tape, it is saved as an MVI file format. However, the MVI file format is not compatible with other programs. Even windows media player refuse to play MVI file. Besides, editing software like Pinnacle Studio and Windows movie maker do not work with the format. Because of this, the files need to be converted to a format that is more widely used, such as AVI so that these videos shot with still camera can be played and edited as easily as other common videos. This guide is to tell how to do that.
Software you'll Need: Pavtube Video Converter
Step 1. Download Pavtube Video Converter, and follow the prompts to install the program. Click "Finish" when the installation is complete, and Pavtube Video Converter will launch automatically.
Step 2. Click “Add” to load MVI files or directly drag the files into file list. By default, the files are selected. If you would like to join all the selected files together, check the box of Merge into one. You could view the files in preview window, simply highlight the file and click play button.
Step 3. Click “Format” bar to determine output format. Follow Common Video-> AVI Video (*.avi)/ DivX AVI(*.avi). Click “Settings” if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels. Do not forget to click “OK” to confirm your settings. Then type in a desired output location in the "Output" box.
Step 4. Click "Convert” to start converting MVI files to AVI. You could set auto shutdown in progress window or leave it there and come back later. After conversion you could edit the converted video in Pinnacle Studio, and make a film out of it or burn it onto DVD.
Learn more: http://www.pavtube.com/guide/convert-mvi-to-avi-for-edit-in-pinnacle-studio.html
on Mar 25, 2010 | Cameras
When i put a cd / dvd on the dvd room. It will not read.
This could be due to corrupt registry settings.If you are using Windows Vista, then perform the steps below to resolve the issue.
=== Backing Up Registry and Registry Key ===
CAUTION: The registry contains critical information and a registry backup is essential. An incorrect registry entry may cause serious system problems or prevent the computer from starting. You will not be warned of any incorrect registry entries. If the registry is not backed up, the only way to recover the system is to reinstall the operating system. Do not double-click the Backup.reg file on the desktop unless you intend to undo the changes you are making to the registry.
1. Click Start, type Regedit in the Search box and click OK.
2. Click "File" in the menu.
3. Click "Export" from the drop-down menu.
4. Click the down arrow beside "Save In" and select Local Disk(C:).
5. Type Backup.reg in the File Name field.
6. Click Save.
=== Deleting UpperFilter and LowerFilter Registry Keys ===
1. Click Start, type regedit in Search box and click OK.
2. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
3. Click the plus (+) sign beside System.
4. Click the plus (+) sign beside Current Control Set.
5. Click the plus (+) sign beside Control.
6. Click the plus (+) sign beside Class.
7. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
8. On the File menu, click Export.
9. In the File name box, type savedkey and click Save. It is better to save the "savedkey" to the desktop.
10. Click the REG_MULTI_SZ data type UpperFilters (found in right window pane) and then click Delete on the Edit menu.
11. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next method.
12. Click the REG_MULTI_SZ data type LowerFilters (found in right window pane) and click Delete on the Edit menu.
13. When you are prompted to confirm the deletion, click Yes.
14. Quit the Registry Editor and restart the computer.
=== Reinstall CD/DVD drivers from Device Manager ===
To reinstall the drivers for the CD/DVD drive, please perform the steps listed below:
1. Click Start, Control Panel, Device Manager.
2. This opens Device Manager window.
3. Click "+" beside CD/DVD Device Category.
4. Right-click the listed CD/DVD/RW and select Uninstall.
5. Follow onscreen instructions to complete the uninstallation.
6. Now restart the system.
Windows will redetect the device on restart and reinstalls the drivers automatically. Now check for the issue.
May 20, 2010 | Computers & Internet
Missing CD DVD driver
The issue could be due to missing or corrupt CD/DVD drive drivers. If you are using Windows XP OS, then go ahead and peform the following steps:
1. Click Start and select Run.
2. Type Regedit in the Open field and click OK.
3. Click "File" in the menu.
4. Click "Export" from the drop-down menu.
5. Click the down arrow beside "Save In" and select Local Disk(C:).
6. Type Backup.reg in the File Name field.
7. Click Save.
1. Click Start and click Run.
method.
15. Quit the Registry Editor and restart the computer.
May 24, 2010 | HP Compaq nx7300 Notebook
My dvd ram is not work and no load anyware disc
Please perform the below steps :
Step 1 # Deleting UpperFilter and LowerFilter Registry Keys
Backing Up Registry and Registry Key:
1. Click Start and type regedit in the text box.
6. Click Save.
Step 2 # Deleting UpperFilter and LowerFilter Registry Keys:
10. In the File name box, type savedkey and click Save. It is better to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right window pane) and then click Delete on the Edit menu.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right window pane) and click Delete on the Edit menu.
The CD-ROM drive, DVD-ROM drive, or CD-ROM R/W drive should now appear in the My Computer window.
Step 3 # Uninstall CD/DVD drivers from Device Manager
2. This opens Device Manager.
5. Restart the system.
I am sure this information helps you. Please reply if I can help you further. I would like to add that we value your precious time and would be here round the clock to serve you.
May 16, 2010 | Computers & Internet
Trouble opening saved image move file in Pinnacle; "trouble finding the downloaded images"; frames seem to have lost the images. Can you help
go into your search box and type in the Pinnacle Studio plus 12, then search all files in your hard drive which should be ( C: drive), any thing with that name will come up then you click on all the files in that folder to look for your images.
Jun 08, 2009 | Pinnacle Studio Plus 12 for PC
Corel x2 problem: Unable to Load Library when sharing to VCD
Hey everyone, I faced the exact same, excruciatingly frustrating problem. After a quick search, I found forum threads telling me that when Corel Video Studio was modified to suit Vista, something about its 3D transitions got messed up.
So, if you face this problem while using Corel Video Studio on Vista, check that you have removed all 3D video transitions and try rendering again.
Jan 27, 2009 | Corel Paint Shop Pro Photo X2
Bad Video quality
Hi.
On the windows update failure for dot net 1.1 there is a way to edit the registry and set a value that tells windows update it was installed. I'll try to find that key and send it or post it back to you, I don't have it memorized.
Can't help you directly with the Ulead Studio, sorry. I would suggest you look over the program options for video playback quality in the program. As you stated, it looks fine in WMP but not in ULS, therefore it should be a property value for playback quality in the ULS program window.
Hope this helped you.
Worldvet
May 23, 2008 | Ulead VideoStudio 9
DVDRW DVR -K17B all of a sudden can't load driver
At the HP chat center i've got this solution ant it worked for me. good luck for those with the same problem.
Normal 0 21 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Deleting UpperFilter and LowerFilter Registry Keys
Mar 18, 2008 | Pioneer DVR-107D DVD±RW Burner
My Windows Move Maker won't let me upload video.....
the codec you need is xvid it should be on the cd supplied with camcorder. in stall that if not then download and install. I don't use windows movie maker I use pinnacle studio 10 plus for editing you have more control over you videos. hope this has helped
May 05, 2007 | Sony Handycam DCR-DVD92 DVD Camcorder
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
