Question about Electrolux Refrigerators
Freezer has a flashing E code and refrigerator has a flashing F code
  • tinastan Jul 03, 2008
    I was afraid that being 4th July weekend coming up and because we live out in the country we would not be able to get it fixed. So glad that this worked.
Rascal said to do a hard reset which entailed unplugging it for 3-4 hours. This morning it worked as usual
Posted on Jul 03, 2008
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Reprogram control board after replacement/ MFI2266AEU B/M REFRIGERATOR, M'TAG
Press and Hold Door Alarm Keypad
Press and Hold temp down keypad
Relaease door alarm Keypad and wait 3 seconds.
The control will display PE to indicate Programming mode.
Entry to programming mode confirmed by pressing FREEZER temp down keypad once more
The control will display the Current unit Programming Control code This code must be validated by comparing it to the Programming code stamped on the unit data plate (Model number plate)
If the programming code is correct all you have to do is close the refrigerator doors
To change the CODE press the REFRIGERATOR up or down keypad to change the digits.
To move between digits press the FREEZER up or down button. Decimal point indicates selection
Once the desired code is entered PRESS and HOLD the freezer temp down button until the CODE entered starts flashing.
Close the refrigerator doors or wait 4 minutes without Kaypad input for programming mode to exit.
That should be what you needed.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Maytag MFI2266AE Side by Side Bottom...
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Kelly
Aug 23, 2011 | Refrigerators
I just replace my control board and freezer fan. I plug the refrigerator in and I get the PE0000 code. I try to go into the program mode by pressing door alarm and then freezer down key for three seconds...
I just fixed mine. With the PE00 0000 flashing press and hold the door alarm key, press the freezer down (-) button and hold, then release the door alarm button. after about a second release the freezer down button and the display should change to a steady PE00 0000 after about 3 seconds. Using the refrigerator + - buttons you change the code. The freezer + - buttons now control the position of the decimal point to change each number position. My code was 0302 (found on the sticker on the inside of the frig, right hand upper side. I had to follow the programming code found behind the kick plate on the right side twice, the second time it worked.
Apr 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Personality code
osborne, you can try this procedure.
PROGRAMMING MODE: (FOR PROGRAMMING A NEW CONTROL)
NOTE:
The Program Code is located on the Serial Plate on this unit after the word Code.
1. Open the Fresh Food door and press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
DIAGNOSTIC TESTS
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program Code. This value should be validated with the
Program Code printed on the unit serial plate.
NOTE: If the Program Code is correct, the Programming Mode is exited by closing the Refrigerator
door(s).
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the
digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad
to select the next digit.
9. Once the desired Program Code is entered, press and hold the Freezer Temperature Down
Keypad until the Program Code begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program Code the control will not save the new code,
but will beep. (The unit will NOT run with a Program Code of 0000).Once the Program Code
has been saved, the Programming Mode is exited by closing the Refrigerator door(s). If the new
code is incorrect this process should be repeated after closing the Refrigerator door(s).
The Programming mode can be exited at any time by closing the Refrigerator Door(s) or
will exit if unattended for four minutes.
i hope i was able to fix your problem.
Jul 02, 2008 | Maytag MFD2560HES Bottom Freezer French...
Power light flashing on & off
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Jan 08, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
223 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
