Question about Kenwood Car Audio & Video
My kdc-328 will not play the cd i put in it. It keeps coming up with toc err. i have reset it couple of times and that's it. what does the code meen?
    Genius:
  • Kenwood Master
  • 1,550 Answers
Maybe the laser lens are dirty clean it
Posted on Jul 02, 2008
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
Kenwood KDC-MP528 CD TOC ERR
Every one of those Kenwoods that I have fixed with that error needed the laser pick up replaced. so there is no easy fix for it.
If you have tried several disc's and they all have a TOC err, and you know the disc's are in decent condition, then you will need the pick up replaced.
First try cleaning the disc you are using. I use windex and a soft cloth like a bath towel, it works great at getting fingerprints and other stuff off the disc without scratching the disc. A bad fingerprint or a bad scratch right at the innermost part of the disc (where the TOC is located) will cause any CD player to not read the TOC, producing a TOC ERROR. you never know, you might get lucky.
Jun 17, 2008 | Kenwood KDC-MP528 CD Player
Toc error
i have had the same deck for four years and installed and removed from 4 different vehicles. the deck has been through some stuff lets put it that way. mine does the same thing as yours, i have found that you just keep ejecting the disk untill it reads. usually only takes a couple times and then mine works just fine.
May 26, 2008 | Kenwood KDC-MP828 CD Player
TOC ERR
this is caused from the pickup needing to be cleaned(lazer) remove deck remove small phillips screw on top plate use a damp q-tip (alcohal) gently rub the lazer top with the q-tip allow to dry aprox 10min reasemble and enjoy. Also make sure u don't need a security code for your radio before u unhook the power plug!!!!
May 16, 2008 | Kenwood KDC-MP228 CD Player
E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Feb 25, 2008 | Kenwood KDC-MP205 CD Player
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
TOC ERR for kenwood cd player
Most likely optical pickup is defective. I may be able to get a pdf service manual if you wanted to try repairing yourself kstahl65@att.net
Jan 20, 2008 | Kenwood KDC-MP228 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Wont play recorded cd's
thats a "table of contents" error. Try using a different program to make your cds.
KDC-MP228 cd no play w/ codes
Gave up on it and bought a pioneer. Kenwood said to take it in to a service center. The service center would have cost me more than the crappy stereo.
Jan 11, 2007 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
44 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
