Question about Sentry Fireproof Safe
My sentry brand safe is malfunctioning. The door is open, but the bars that lock it are engaged and extended (as if the door were shut and locked). When I key in the code, the green light comes on, meaning that the handle should turn and the bars should retract but they don't move. Therefore, I can't shut the safe. Does anyone know how to reset the passcode?
  • 1 more comment
  • Anonymous Jul 21, 2008
    I have a Sentry R4132 and it's open with the bars engaged. The passcode will not allow the bars to retract. How can I reset it?
  • Anonymous Mar 22, 2014
    key will not unlock the lock so that the combination can retract the pins
  • Anonymous Mar 27, 2014
    I think a piece of paper is jammed in the door as I know the code green light works and key turns just wont open
My bars are engaged my key pad fell in aand i lost keys who should i talk to?
Posted on Nov 24, 2008
Try unlocking the round key hole. It should pop the mechanism out. While it is out, try your password again and it should retract the bars.
Posted on Oct 28, 2008
My sentry safe, number bx-887566, is stuck in the open position. The lock is engaged and the key won't turn. How do,I fix this??
I did this on my own safe. Different brand but you can try. Somewhere on the door , look for a latch or pin or rod that you can push in.These are usually triggers that allow the lock to turn only when the door is closed. Somehow, you have locked it with the door open (as I did). Press in any of these and try turning the lock. It will be tricked into thinking the door is closed and allow you to turn the key. Good luck
Dec 03, 2014 | Home Security
Bolts on a SentrySafe A3860 are stuck retracted in the door.
Sentry's Customer Service Department is available Monday through Friday, from 8am - 6pm, Eastern Standard time. Our internet Frequently Asked Questions can be accessed on line 24 hours a day, 7 days a week at www.sentrysafe.com
Dec 28, 2013 | Sentry Fireproof Safe
I closed the lock with the dolor open and it will recognize my six digit code
tip from a1 locksmith burlingame you simply have to re enter the lock combination retract the bolts then you should be able to shut the door and lock it.
Oct 03, 2013 | Sentry Fireproof Safe
I have a Sentry safe S5741. I have the electronic combo and the key. The door to the safe was locked with the door open. Now the door will not unlock to shut the door. Is there trip to reset the door? Is...
Try changing the batteries first. No the electronic combo would not be erased unless someone previously changed the combination. There is probably something causing the bolts to not retract. The lock may fail if there is any pressure on the bolts and or the door of the safe. Hopefully this information helps.
Jul 12, 2011 | Sentry Fireproof Safe
My Sentry safe MS0100 combination dial will not turn. I can open the door but can not turn the dial to lock it.
If the safe is brand new.. you must first remove the locking screw at the base of the combination lock dial lockcase.. discard the screw.. Make sure you have the owners manual with the sticker and default lock code nearby before locking the safe.
The factory has a preset combination code that cannot be deleted. It is on the owners manual. You can use that code if your codes have become compromised.
Also ensure the batteries are fresh. This may also be the problem.
Anything beyond this will require assistance from Sentry. Your serial number is on the side of the door. Have that ready.
www.sentrysafe.com
Best of Luck
Apr 16, 2011 | Sentry Fireproof Safe
Can not lock door, works fine when open but will not lock when closed, handle wil not go up all the way. Sentry A3150
There might be 3 problems:
1. The door is not aligned anymore.
2. There is something in the frame where the lock goes in.
3. There is internal malfunction.
If you are sure about 1 and 2, you need to take it for service/repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 09, 2010 | Sentry Fireproof Safe
My brand new csw3607 does not lock.
take it back and get a new one or.
http://www.sentrysafe.com
the instructions are located link above.
mj
May 31, 2009 | Sentry Fireproof Safe
New sentry csw3813 stuck open
Remove the screw from the backside of the door.
Feb 25, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,253 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
