Question about RCA HD52W59 HDTV Projection Television
Liquid spilt on front of RCA HD52w59
This set was a freebie and had somthing spilt on the front of set. The previous owners took it to a RCA repair shop, and the tech. cleaned the middle CRT board. It worked for 2 weeks and stoped again. Now there is no sound or pic. The power light blinks and thats it. Is this worth fixing? Bill
    Genius:
  • 1,139 Answers
Hello billew0481,
This might be a switching power supply problem. Since whatever may have spilled got on the broad and over time dried and shorted something out. While this is a possibility, I think that in this case the two incidents are not related. I think that you do have a power supply issue but the spill is not related. Is it worth fixing, That's up to you to decide the only thing I can do is to tell you what the problem may be and give you possible prices. For this job you are looking at a high end payment of $1000.00 if the IHVT, HOT, and High Voltage Tripler (along with associated circuitry) is defective. However it could be as simple as a fuse being defective. What I would suggest is getting an estimate based on a technician troubleshooting the Tv and determining what is wrong. at worst you'll be charged $100.00 for the house call. It's up to you then to decide to get it fixed or not.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 20, 2008
My RCA HD52W59 problem
set is prone to two problems: high voltage splitter at front of set behind speaker grill arcs-------also set does have parts on HV board that do the same thing---HV transformer feeds voltage to the splitter.
Jun 07, 2012 | RCA HD52W59 HDTV Projection Television
I need the owner's manual to my HD52W59 television
you can get the owners manual for free from www.tvrepairworld.com just send them a email with your model number to customerservice@tvrepairworld.com
Oct 13, 2011 | RCA HD52W59 HDTV Projection Television
I have a 52'' rca hd52w59 i have sound but it takes some time for the picture to come in a when it does its not clear it take about 40 mins an then its fine
as this is a rear projection tv, I wonder if the lamp is fogging up when not in use? is the area where the tv is situated damp at all or could something have been spilt into the set?
May 03, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 no power
These sets have alot of different problems, for deflection boards and SSB boards Call UED 1-800-648-6657 SSB board can shut set down, you might just consider calling repair shop.
Jun 03, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59, Convergence is out, not even on set up menu, and also the picture is bowing. how much to fix or just use it for target practice
you can fix it for 24.00. You can get the ITC222 & ITC222A convergence option missing repair kit at the following link which contains the parts and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | RCA HD52W59 HDTV Projection Television
Pioneer CDJ 1000 - Jog Wheel not working.
Take it to your nearest pioneer repair centre as this liquid will have to be removed before it causes further damaged, you can send it to us if you havent had it repaired.
Regards.
http://www.audiovisualservices.info/
Oct 26, 2008 | Pioneer CDJ-1000 CD Player
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
