Question about GE Spacemaker JVM1640SJ Microwave Oven
Turn table/Spacemaker Microwave
I have a JVM 1540. The turntable continues to turn slowly when not in operation. When I open the door it stops.
  • 1 more comment
  • jatcat007 Jul 02, 2008
    GE Spacemaker XL Microwave Oven
    Model JVM1650CB006
    Serial No. SF902282B
    Problem: After a power surge, I can not turn off surface lite. All other operations on microwave are working fine. I have tried changing bulbs. The only way I can turn off the surface lite is to unplug unit or turn off electric breaker.I appreciate any help. Thanks.
  • ctortarelli Dec 22, 2008
    My turntable does not shut off after the microwave stops. Even the turntable off/on button does not stop it...the repairman is shceduled for the second time. I am still less tha a year old. The first time he repalced the electrical panel. It worked correctly one time and now when I use it the turntable still runs. Opening anc closing the door, using the stop switche, nothing stops it. have unplugged the unit, awaiting my second service call..not happy
  • Anonymous Mar 24, 2014
    no noise from inside and no table turn
  • GE Master
  • 9,098 Answers
TO jatcat007
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly. (See below)
We're happy to help and we appreciate your thoughtful rating of our answer.
TO demps61
Chances are you have a bad door switch or loose door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 06, 2008
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacemaker XL1800. the model number is JVM 1842 BD. The turn table has stopped turning. There is a turn table control and that is turned on. how do I go about repairing it? also, wher
The full model number from the tag on the unit would be JVM1842BD001 or JVM1842BD002 without the spaces.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 07, 2013 | Microwave Ovens
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table stop turning and wont heat
Your oven has a couple of switches inside that are operated by the door latches. One of them controls the power to the turntable and magnetron tube power transformer. The switch is either out of adjustment (which can happen if the oven door gets closed real hard) or is bad. I would suggest letting a professional check the oven and repair the problem. Door repairs have a direct effect on microwave leakage and it's better to have them done safely.
Dec 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My jvm 1540 will not heat. any advice?
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 31, 2010 | GE Spacemaker JVM1540 Microwave Oven
We have a JVM 1443bk02 ge microwave. Today the turntable stopped working. You can depress the key pad on/off button but that makes no difference for the turntable. How do you test to make sure it is the...
The problem with the turntable could be the following:
  1. Gummed up lubrication or bad bearings. Check to see if there is any food on the turntable spindle.
  2. If that is ok, check to see if the belt is loose or broken.
  3. If that is ok, check the motor. A meter will confirm whether there is power going to the motor, when you depress the keypad on button. Use the AC Volts setting, if you have about 21 VAC and the motor does not work, then the motor is bad.
Jan 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave oven turns on when door is opened.
woow! stop right now!!!
its the door safty switches?? dont use it any more till you get it sorted out, if you get a blast of microwave energy hit you in the face it could well blind you,,,
now see why you should stop using it?
please play it safe,,, its realy not worth spending good money on an old microwave when they are so cheep to buy now,,if i was you i would just dump it and buy a new upgrade model
Oct 25, 2009 | Microwave Ovens
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
Jul 02, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
180 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
