Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1991 fatboy
Hi saw your replies seems you know bikes. I'm stumped. I bought a 1991 fatboy with only 10,000 on it. Mint clean bike. But I can't get it started. At first it would turn over and not fire. Now it just clicks. I put my finger on the breaker and can feel it clicking , tried to arc the post to see if that works to get power through.. no luck though . The battery is new and charged. The cables are all tight .
any help you can offer would be great.
Ty
  • cdn-rider Jul 02, 2008
    Wow , thank you for ALL your suggestions. I will for sure take all the info into consideration. As well pass this site on .
    what you have described seems to be what is happening. there is a recall on the starter relay , and 30 amp breaker.......
    the info you provided makes total sense......
    thanx again ,
    Ty
    Brigadier General:
  • 6,966 Answers
Appreciate the vote of confidence but there are a few others who are likewise knowledgeable if not more..
On to your concern, it would seem you have two (2) issue, 1st if wont crank and the second will crank but not start.
No Crank: Due to the massive current required by the starter a component is installed between the starter button and the starter. This component then switches the battery to the starter motor. In cars this is the starting solenoid, in most bikes, this is the starter relay. Normally in the starter relay there would be 2 big terminals for the battery and the starter motor cables with 2 smaller wires for the starter switch and ground. Try this - try pushing the start button with the headlights on, if the headlight dims considerably, then the starting relay is good and the motor is bad; on the other hand if the headlight dims just slightly or not at all, it is the starting relay (the one with the clicking sound).
Most starter motor problems could be:
1. the bearings/bushings at the ends of the armature;
2. carbon brushes;
3. commutator segments (the multiple small copper plates that the brush contacts with).
However, it may be to your advantage to simply replace the motor should it be deemed defective, difficult to secure parts or not economically reasonable to go down component level repair.
Will Crank but not fire: There are 2 major requirement for a gasoline engine to fire, fuel and ignition. No fuel could be verified by removing the air cleaner and pouring a small amount of fuel down the throat, start the bike, if it start and runs (even for just a moment), you have verified the fuel problem. No ignition could be verified by removing one of the plugs, reinsert the high tension wire plug to the sparkplug and place the sparkplug atop any metal part, crank the engine, there should be a spark at the plugs.
Pls post back results whether fuel or ignition and we can go further from there.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
Hi i have a 2006 kx 250 2 stroke.. my bike makes a knocking sound form the bottom end since i bought it.. many said kawasaki kx 250s in many of those yrs have had that sound. the bike runs mint and...
Knocking is not normal. No manufacturer is going to build in a knock. The problem could be a con rod big end bearing, the balancer could be going bad, wrist pin may have worn out the pin mount holes in the piston, or piston slap. The underlined problems are the most likely. Please rate my answer. tombones49_225.gif
Aug 09, 2011 | kawasaki GT650S Sport Comet 650 S...
I bought a 1991 gsx600f and it was dieing when the bike was cold or warm and would stick up at 3000 if i gave it gas. bike dosent die if i ride it but when it drops under 300 rpm the bike stumbles and...
Hi, Timothy_towd "ABSOLUTELY" you need to go through all 4 carbs set the proper float height and then have them synced for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Mikuni CV Carburetor Cleaning for Suzuki Honda Yamaha Tutorial
1997 Suzuki katana 600 carb sync
Suzuki GSX600F Service Manual
OEM parts for Suzuki
Suzuki GSX 600F 2000 Owner Manual
Apr 09, 2017 | 1991 Suzuki GSX 600 F (Katana)
1991 fatboy
There is a large diameter rubber hose on the right hand side of the bike. At the end of this hose is a plug. The hose ends down on the frame to the rear of the chrome transmission end cover. Loosen the hose clamp and remove the plug to drain the oil tank.
Mar 12, 2010 | 2003 Harley Davidson FLSTC Heritage...
I just bought a mint 1983 gs1100ed with 24000 miles. Are there things to look out for at this mileage
rock solid bike. change all the fluids and filters.check and clean the petcock filter that is inside the tank. clean the carbs.. this bike will have cv carbs, check diaphragms for pinholes.
Jan 11, 2010 | 1983 Suzuki GSX 1100 E
Bike cuts out at 10,000 rpm
Eventually it won't start at all if you keep redlining her like that. My advice to you is get a faster bike.
Jun 20, 2009 | 2005 Honda CBR 125 R
Fob on 2004 fatboy
The FOB is a security device that will help protect your bike. If it is far enough away (i think 20 feet) your bike will not start, Without the FOB the fuel pump will not run and the lights will flash on and off. When you come back to the bike with the FOB the bike will run normaly. So do not leave it with the bike unless you want it gone when you come back.
Jun 14, 2009 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Loss of power around 8 -10,000 revs in 3/4 gear
ello m8,,hows things,,clean out the air filter 1st, change all your plugs mr,try that , if nothing u will need to get the carbs balanced to by a bike shop,mechanic,,unless u have carb gauges,,, itl be easier if they do it,, try these 1st m8,, if no joy come back and il go threw step 2 with yuh,,
Feb 25, 2009 | 1991 Honda CBR 250 RR
I want to convert my motorbike like a sports cruiser
Your best bet is to custom make or adapt other parts to your bike. the best way if you are not used to doing this is to pic up a cheap parts bike that is more like where you want you bike to be when you are complete and start swapping and adapting parts till you start getting the results you want!
Dec 30, 2008 | 2001 Honda CBX 250 TWister
Bike won't start - 2004 Fatboy.
test your battery.or if you have a jumper box hook it up to your battery and try starting it if it starts you know its your battery.Have a Merry Christmas and Happy New Year of riding.
Dec 14, 2008 | 2005 Harley Davidson FLSTSC - FLSTSCI...
Lands Phones Logo
356 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
