Kitchen Hoods
Problem for Kitchen Hoods
Generic problem for all Kitchen Hoods
Ventahood fire suppression systems
By hvacdude on Jul 02, 2008
Hello
I have to wire a ventahood fire supression system control panel (control head) so that the exhaust fan comes on in case of fire and basically all other circuits under the hood are shut off. The ones being shut off would include a supply fan the lights under the hood and the receptacles under in approximate vicinity of the hood, All the cooking appliances under the hood are gas which will be shut off mechannically. If possible, could you please supply me with a electrical and a mechanical diagram for the electrical and gas shut off. Basically I need to know how to wire the microswitches and to hook up the gas shut off
Sincerely
thank you
Russell Robbins
Same Problem
Aug 15, 2008
-   I need to know how the fire cutt off is wired between hood lights,plugs and supply air with 2 pole contactor thru micro switches in ansual system-   Guest
Jul 07, 2008
-   the resstaurant that i have taken over has no relay in the electrical box that makes the whole ting work where can i get the relay and can i do it myself-   Restaurantin
Solution #1
posted on Sep 17, 2009
Not Rated)
aaaelect
Rank: Apprentice
Rating: 100%, 1 votes
the micro switches have a common hot/normally open&normally closed.The way we install the system is with contactors .Landing the line and load on the contactor lugs and powering the coils with the n/o or n/c side of the micro switch . exhaust turns on and make up air,all electrical and gas shuts off.
Was this helpful?
Yes
No
Solution #2
posted on Sep 30, 2008
Not Rated)
littlejohn19
Rank: Apprentice
Rating: 0%, 0 votes
I went to greenheck by google, www.greenheck.com/products/kitchen/wiring.php
It helped.
Was this helpful?
Yes
No
Solution #3
posted on Aug 23, 2008
Not Rated)
hurleyway
Rank: Apprentice
Rating: 0%, 0 votes
the wiring has to go to the microswitches
you can add up to three micro switches,they are located in the control box
there colors should be bl,brown and red
look for nc or no(you can depress the switch by hand to see when you press itup it shuts power
it has to be repeated for the light,plugs and make-up air
to pass inspection when you press up on switches the have to shut off electric lights and make up air
you dont need a relay.
the basic system is a contactor line and load runs exhaust and make up air power in power out.
you need power just for the contactor to pull in.
you need to add a switch break hot on contactor power
Was this helpful?
Yes
No
Popular Solutions for Kitchen Hoods
Questions and Unsolved Problems for Kitchen Hoods
Answer
I am looking for a new plastic switch set for a Faber hood extractor model number INCA HC HILO 72.... (More)
Answer
Where is a good place to purchase replacement bulbs for my Tecnowind vent? It looks like the base is... (More)
Answer
Baumatic FCC 2002 hood extractor fan not working, just makes a buzzing noice?
Answer
why my new over the range microwave hood lg 30 does not have power
Answer
What is an allowable distance between the range hood elbow to horizontal and the external blower... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Hood Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Affordable, Available &...
Appliance Parts & Repair Service
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
