Question about Canon FaxPhone L75 Plain Paper Laser
Paper jam keeps occuring. Have put in one paper at a time and multiples at a time. Have turned the machine off (unplugged) and back on. Have purchased a new toner. Continues to jam. What do I do now?
Sounds like something is blockin the paper path,
Posted on Jul 02, 2008
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
I had a paper jam in my epson tx600fw. took the paper out. then when i turned it back on, it still says paper jam. There is no paper stuck in machine yet everytime i turn it on it says there is a paper...
The printer needs to be reset. First try unplugging it to see if it resets. If not you will have to look at the manual and go into maintenance properties to reset it.
Apr 07, 2011 | Epson TX600FW Series
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
PAPER JAM ERROR MESSAGE keep showing!!
Make sure that all rollers in the paper tray is working properly. If not, then this might be the reason why your having this issue. Try calling your manufacturer to have it replaced, if it's still under warranty.
Dec 03, 2009 | Office Equipment & Supplies
Message states paper stuck in printer, but no paper is visible.
This often occurs either shortly or immediately after a paper jam in which someone has to pull out the paper that was fed through, tearing it at the same time. A small piece is still in the machine somewhere. If there is a back panel you can remove from the printer it often helps to remove that. Unplug the printer, check with a flashlight, and you'll most likely need tweezers once you find it. You should also be able to roll the paper feeder by hand with it unplugged, if not, check near the gears or at a point where it may block multiple pages from feeding.
I've lost count of how many printers were given to me by owners saying it was broken, and all it was was a tiny peice of paper crumpled up inside.
Jul 15, 2009 | Canon PIXMA iP2000 InkJet Printer
Whenever i place paper on tray paper jam occurs
your pritner need some sericing of fuser assmbly and roller.
Jan 03, 2009 | HP All-in-One Printer
Canon MF3240 Paper Jam - No Real Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Document jam
I had this totally annoying problem this morning. After looking for any obvious paper jams or small bits of loose paper, I tried several fixes: 1) open front cover, release levers that hold white rollbar in place, roll the bar forward to make sure nothing is stuck behind it, snap levers back in place; DID NOT fix the problem; 2) open top cover, remove print cartridge, look for jammed paper bits, close cover; DID NOT fix the problem; 3) unplug the machine, wait a few minutes, turn machine back on; DID NOT fix the problem. I even unplugged the machine, opened ALL the covers, turned the machine upside down and shake it to see if any paper clips, staples, or other objects have fallen inside the machine; DID NOT fix the problem. FINALLY, I pulled the paper feed tray forward, reached down to the feed rollers, twisted them a few turns, put paper back in the machine, and the "paper jam" message disappeared! This may not work for everyone, but it worked for me today, so I hope this helps someone out there to have a better day.
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother mfc 4800
TRY UNPLUGGING IT FROM THE WALL 12 SEC AND PLUG IT BACK UP
Jan 17, 2008 | Office Equipment & Supplies
Canon FaxPhone L75 Plain Paper Laser Logo
69 people viewed this question
old marine
old marine
