Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Help! how do i fix my ipod shuffle? it keeps blinking a yellow-green light and when i go to itunes and open the ipod, it says empty although tons of song were on it!
    Problem Solver:
  • 4 Answers
Go to Itunes and go to the part that shows how much capacity the ipod has and on that same page, you will see reset ipod. just click it and ipod will be back to new but the songs will be deleted.
Posted on Jul 03, 2008
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
1st series ipod shuffle...working fine did latest install from itunes and now ipod will sync but won't play...does repeating of green and orange lights. Tried the restore and resetting but still not...
Here's simple steps to cure the problem if your iPod shuffle won't play and does that green-yellow-green-yellow-green-yellow blinking thing:
  1. Plug in iPod shuffle
  2. You'll notice the "Podcasts" play list under your iPod volume.
  3. Delete the "Podcasts" playlist.
  4. ITunes will re-sync
  5. Unmount the iPod Shuffle and everything should be fine.
If that doesn't work try the link below. It's for the iPod Shuffle (1st generation) restore utility.
Hope it helps.
http://support.apple.com/kb/HT1238
Oct 24, 2009 | Apple iPod shuffle MP3 Player
Ipod Shuffle is not working! Please help!
I had the same problem with a new 2nd gen shuffle connecting it to my PowerMac G5 (OSX 10.4.11) with the latest iTunes (8.0.1). The problem is in the connector. The shuffle using the same connector for listening, syncing with iTunes, and charging. It appears to be insufficient for the G5 to interface with it because when I swapped it for a new Nano, the Nano worked just fine. I tried 2 new 2nd gen shuffles (and hours with in-store so-called genius's as well as tech supp in CA and noone could come up with a resolution). So I figured it had to be in the cable interface (the Nano using a multi-pin connection like the old ipod's used to) and that was exactly the problem. I spoke to someone who said they had a G4 and the shuffle worked fine with that, so it must just be a G5 issue.
Hope this helps....
Oct 20, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Shuffle not working, blinking green-yellow led.
You can log on to the apple shuffle instruction manual and its all online.
hope that helps!
Aug 03, 2008 | Apple iPod shuffle Second Gen. Silver (1...
this is totally a error 1418. Search my answer regarding this problem, it is totally fixable. don't get rid of it. I just fixed one 2day and I'm now preaching the good news.
Jul 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jun 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Try to do a restore:
Connect to your computer and open itunes.
When you first open itunes you should be in "Devices"
Make sure you're in the "Summary" tab and you will have a button that says "Restore"
Click that and it will do the rest.
Dec 28, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Green/orange flahing light on IPod and no music.
From Apple.com Support Website. If the front status light on your iPod shuffle blinks orange and green when you press any button, then your iPod shuffle is experiencing some type of error. Try these troubleshooting steps to resolve the problem. To troubleshoot the iPod shuffle error light: 1. Turn off your iPod shuffle 2. Wait a few seconds 3. Turn your iPod shuffle back on again If this does not resolve the problem: 1. Check to make sure there are songs on your iPod shuffle 2. Use iTunes to add songs to iPod shuffle and try again If your iPod shuffle continues to display a blinking orange and green light, use iPod Updater 2005-02-11 or later to restore iPod shuffle, and then add songs with iTunes. If your iPod shuffle still shows a blinking orange and green light after trying all of the above steps, your iPod shuffle may need service. Best of Luck.
Sep 11, 2007 | Apple iPod shuffle MP3 Player
IPOD Shuffle doesn't work at all
blinks green.
Jun 13, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Hi
Ur Ipod shuffles needs to be reset to factory setting, you will find the utility for Mac and windows machine at:
http://support.apple.com/kb/HT1293?viewlocale=en_US
http://www.techspot.com/downloads/3726-ipod-shuffle-reset-utility.html
1. Reset the ipod using the utility
2. Run itunes application to create profile : after you have reset the Ipod just start itunes and it will ask you to provide a profile name, just provide any name and select okay.
I had the same issue, got it sorted using the windows utility.
Should work for u as well.
Thanks
Krishnendu
Mar 20, 2006 | Apple iPod shuffle MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
55 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
