Question about Nikon Coolpix S51c Digital Camera
Nikon Thanks, Ekse - I tried the reset function - nothing happens. I also opened a brand new memory card; put it in (unlocked..) - and got the same message. Start to think that there is something wrong with the camera...I have a Mac - I don't know how I can reset the card - I do not have any appropriate slots.
  • 13,433 Answers
Ok, take the camera to nikon for service, do you have warranty on it?
Or you can take it to a local camera shop they can look at it or direct you to someone.
Posted on Jul 02, 2008
My camera wont take pix says slide lock to write position, when I do that it display "CHA" don't know what that means and still can't take pix
CHA also means the card cannot be used for other reasons. F.i. the card can be damaged. Try to format the card. That is, when you could use the card before. If you bought a new card, Make sure it is not a SDXC card, because your camera only allows MMC, SD and SDHC cards. If nothing helps, also look in the memory card holder, if nothing strange is in there, or the sensor that looks for the lock, is functioning correct. If you don't know how, please visit or contact a Nikon-Authorised service centre.
Feb 13, 2014 | Nikon D5000 Digital Camera
I tried to put a new memory card into my coolpix s3000, but now it just stays in a weird frozen state with the lens extended. The screen is on, but it's black. I can't turn it on or off. Nothing I do...
Remove the battery and the camera will shut off. keep the battery off for 12 hours and reinsert back. Remove off the new memory card and switch on with a foramtted memory card.,, maybe the old If the camera resets back to life and functions well then checck if the new memory card has some virrus in the memory, if so scan and delete and format the card.
However if the fault still stays on then you have a fault in the main processor conttroller of the camera which will require extra help.
Hope you take this tip. credit me if this works.
Aug 21, 2010 | Nikon Coolpix S3000 Digital Camera
New Coolpix L20. Driver does not install with Windows Vista. Have un-installed all USB, re-booted, etc, but nothing helps. Have inserted Nikon CD and tried installing driver from there, but still...
Greetings,
I would take out the SD memory card and use it with a card reader like this one: http://bit.ly/5fruhB . You simply take out the SD memory card and put it in the card reader. Then put the usb end of the card reader into your computer and download the pictures that way.I also recommend that you download Picasa, a free photo organizer/editor for your pictures: http://bit.ly/5f6HEt This way you bypass the lousy nikon software altogether. Hope that was helpful,
Take Care,
-WN
Dec 22, 2009 | Nikon COOLPIX L20 Digital Camera
I have a Nikon L100 and lost my manual. I can't
format the memory cards after you back it up. if that doesn't work, try another brand.
Nov 19, 2009 | Nikon COOLPIX L100 Digital Camera
Memory problems Nokia N95
hi thanks for using fixya!
Try to insert a new memory card, with a lower capacity. In regard with you unit, just make sure that your Nokia is original as you know there are so many fake units of Nokia N95 now adays, To install a new firmware, you should go to a Nokia Care Center, make sure that it goes with the warranty.
If you need further assistance, let me know
May 27, 2009 | Nokia N95 Cellular Phone
Nikon 4600 coolpix
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 08, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon memory card
One moment geting the reset instructions for your model..
Jul 02, 2008 | Nikon Coolpix S51c Digital Camera
Error 10 message
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Aug 08, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix S51c Digital Camera Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
