Getting air flow ststus, tv will shut down - Televison & Video
  • scottkrkb Aug 29, 2008
    air flow problem will shut down in a few seconds
  • Anonymous Oct 21, 2008
    After cleaning out the TV I am still getting a blocked air flow warning and the TV shuts off
The problem is the sensor next to the lamp. I had the same problem but since i had a warranty they came out and replaced the sensor. That fixed the problem. If you are tech savy than it shouldn't cost more than $15 to fix your tv if not it'll be a lot more.
Other suggestion is to get a vacuum and clean out the junk from the back of the tv. If you can take the back cover off and give it a good cleaning. Also pull out the lamp if id doesn't scare you and clean out the openings with a vacuum
Posted on Mar 15, 2009
I have a mitsubishi 1080p wd-65731 just replaced lamp , tv comes on works fine for about 30 minutes and then shuts off , cleaned vents good , has good air flow light that says lamp turns red in the fr
Could be the fan. It will cool tv but could also be to much for tv to handle.
You can also try reseating the lamp. It may say ok but be wrong.
I have a Mitsubishi 5500 projection tv . have had the type of issue you have had and I have replaced a lamp as well.had to reseat the lamp three times before it worked without shutting down.
Hope this helps.
Jan 14, 2015 | Mitsubishi Televison & Video
Shuts down unexpectingly when running game programs
Is the Laptop Overheating? During intense game play your Laptop will Overheat if it's not getting sufficient air flow. Try cleaning the Fan, vents, heatsing with Compressed Air, Improve air flow through the Laptop, a Laptop Cooler is a option. Try shutting down unnecessary processes, I use freeware RAZER GAME BOOSTER, you configure what you want to shut down: http://www.razerzone.com/gamebooster Remember, Your machine usually shuts down for a good reason, it's trying to protect vital components. Overheating will fry the CPU, Graphics Adapter, etc.
May 11, 2013 | Gateway NV73A17u Laptop
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
Tv blacks out and saids block air flow
Call Mitsubishi and they will tell you a authorized service center in your area to come out and fix this issue. They have a recall on the thermal sensors in these sets. They will pay for the repair.
Oct 17, 2009 | Televison & Video
Mitsubishi TV air flow
open the back of the television to check for dust buildup on the heat fins and other components. As well as the fan.
Mar 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi DLP 1080p TV with air flow problems
Hello ags98,
First I would suggest that you re-seat the bulb and then check the cooling fan, and air flow path. In addition to checking the fan make sure all air flow ingress and egress vent are unobstructed.
I hope this helps
Thank you,
Shuttle83
Oct 01, 2008 | Televison & Video
My mitsibishi tv says its not getting enough ventelation and it shuts down. what can i do
Hello bobtail0915,
This means that your set is not getting the proper amount of air flow in order to remove dissipated heat from the set. I would suggest moving the TV to an area with better air flow. Make sure that nothing obstructs the ventelation slots on the back of the TV set. This should help.
Thank you,
Shuttle83
Jul 13, 2008 | Televison & Video
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
