Question about Apple iPod touch
What button do i press?
The menu or the power button? Sorry.
  • Cassidy Dvorak
    Cassidy Dvorak Jul 02, 2008
    Yes. i didnt see it the first time, im really sorry. But thx.
  • Apple Master
  • 13,433 Answers
Can you read this page?
http://support.apple.com/kb/HT1808
Posted on Jul 02, 2008
  • Ekse Jul 02, 2008
    ok Im sorry for being rude, its 6am here haven't slept yet.
    Let me know if you need anything else.
    Thanks,
    Ekse
How to hard reset a craig 7 inch netbook
1. Power off the unit
2. Press "Power On/Off" and "VOL+" button together until "Android recover Robot" appears then release.
3. Press and hold the power button then right after press the volume + button then release. repeat until the blue menu appears.
4. In recover menu, "Volume +" & "Volume --" button control "Up" & "Down", Power On/Off button as "Confirm" button
5. Select the option "wipe data/factory reset"
6. Press "Power On/Off" button to confirm, scroll down using the volume - button to option stating "Yes -- delete all user data" and press "Power On/Off" button again.
7. Select the option "wipe cache partition" and press "Power On/Off" button to confirm
8. Select option at the top of menu "reboot system now", press "Power On/Off" button to confirm selection.
Aug 04, 2015 | Computers & Internet
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Sony Cyber-shot DSC-T7. Pressing Menu button does not access any menu. Can only access Image Size menu by pressing Image Size/Delete button.
I'm sorry that the Menu button on the Camera is not working. Please try a power resetting and check the operation:
To perform the power resetting, remove the battery, press and hold the power button for more than 5 seconds and then reinsert the battery.
If the issue persists after resetting, service may be required. Please click hear to locate your nearest service facility.
Thanks for understanding. Please let me know if you require further assistance.
Jun 19, 2011 | Sony DSC-T7 Digital Camera
How so I set the clock on a Jvc kd-s15 cd player
Hello... sorry to hear you are having problems. What you will need to do is to power the radio up and press the "sel" button and hold it. It will take you to the main menu where you will then use the left and right button (the one that changes the radio stations) until it tells you "clock h" then turn the volume knob to set the hour, then press the right arrow again and it should say "clock m" then turn the volume knob to set the minutes. After that, press the "sel" button again and it will take you out of the menu. Hope this helped!
20 year car audio/video installer
Bay manager
Mar 14, 2011 | Car Audio & Video
Blank playstaion menu screen no more sound help
sorry for the last post: Was thinking about connection problems:
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
I have Phaser 3100MFP/X This printer has 1 problem, problem is "fuse temp error" i cant fix this thing. 3100X is different 3100MPF can you help me to fix. Sorry about my English. Sincerely
To try solving the error: CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
NOTE: This procedure will delete all pending jobs that have been sent to the machine.
To reset the Fuser error:
(Click on one of the following links to jump to the corresponding section.)
To reset the Fuser error for the Phaser 3100MFP / S
Press the [Down] arrow (Menu) button on the Control Panel.
Press the asterisk [*] button.
Press the pound [#] button.
Press the [OK] button.
Press the [1] button. ("00100001" changes to "10100001" at SOS1)
Press the [Stop] button.
Press the [Down] arrow (Menu) button.
Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Power the machine off, and then power the machine on.
Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
Make a copy to check machine operation.
Hope it works for you. Don't forget to leave your feedback. This can help others.
Nov 16, 2010 | Office Equipment & Supplies
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
It will not turn on
I have to ask.......
Power cord plugged in correctly?
Power coming out of the wall outlet? Try a lamp or radio to be sure.
Is the power adapter cord fully seated in the printer?
Can you chesk the power adapter with a mutimeter to be sure there is voltage at the printer end of the cord?
Sorry to ask such normal questions, just making sure.
You may also try this
Resetting to factory defaults
You can reset your printer to the original settings without using the printer menus. NOTE: Resetting to factory default settings will delete all the printer settings you have previously selected.
Step 1
Make sure the printer is not in Power Saver mode. Press and hold the power button for two seconds to turn off the printer. If you have set the Power Saver timeout in the Setup menu, press and hold the power button according to the time you set in the menu.
Step 2
From the printer control panel, press and hold the green button and the red X, and then press the power button to turn the printer on.
Sep 25, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Canon mp150 code
It is not recommended to use refilled cartridge. because it will damage your printer, if it's happen, better to buy new one. the parts is expensive and almost same as brand new printer. Try this to reset the waste basket
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 13, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Apple iPod touch Logo
15 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
