Question about Canon 75-300mm f/4-5.6 III USM EF Lens
I have dust under outer lens on my 75-300mm f/4 -5.6 III USM
I keep having a dust spot on my pictures so afters lots of cleaning and trying it over and over, I found the dust but it is under the lens, I think I can just unscrew the 3 little screws and use my blower to remove it then replace the screws, but not sure what would happen do things need to be aligned? with it still make nice photo's any ideas kinda of nervous to just started taking things apart
thanks
Justin
  • Anonymous Mar 21, 2009
    I was about to give away an old Canon zoom lens ef 75-300mm 1:4-5.6 II that I couldn't seem to dismantle to clean until I read this. Thanks guys!!!
    New Friend:
Front element? You can remove this without alignment worries. The lens zoom mechanism tends to **** in the dust.
Have a look at the front element outer ring. There are 3 black screws. Remove these using jewellers screwdriver (y'know, a very small posi-drive one!). Remove this plastic outer ring. Now you can see three small silver screws, that are about the same size - when you try to unscrew them, they just rotate...
This is as they are not screws, but as mentioned elsewhere - they are plugs (if you notice, they are slightly under the casing. Get a small flat bladed screwdriver, and gently prise them out. Now you can just drop the front element into something sensible - like a microfibre cloth (give it a clean whilst you're there.
Get a rocket blower (NOT canned air), and blow away the dust, and you can use the microfibre cloth (or similar) on the small inner front element.
Then replace the outer front element - you will see where it drops into place - there are plastic guide tabs. Push back the silver 'screw' plugs.
Then screw back on the plastic outer ring and you're done - takes 20 minutes at the most.
Posted on Jul 30, 2009
  • Megan
    Megan May 20, 2014
    how do you remove these small plugs aside from the flat screw driver?
Well I just found that the y are not screws but plugs, and if you use a small screw driver you can pull them out and th elens drops out . Now all I need is some pne to tell me how to get the outer case off the inner.
Posted on Jul 29, 2008
  • 667 Answers
If you wish to attempt that, there are other steps involved before removing the 3 screws. The circuit connection is attached to the mount ring, held by 2 screws in the channel of the mount. You may need to free the center plastic on the mount to remove the ring itself. ( I am going from memory, I don't have a lens on hand to look at )
Posted on Jul 08, 2008
Best telephot zoom lense for my canon 1000d
That's a decision only you can make. What's most important to you? Long focal length? Wide zoom range? Lens speed (maximum aperture)? Weight? Cost?
Also, what do you want to do with the lens? The best zoom lens for taking wedding pictures is not necessarily the best zoom lens for taking sports pictures.
Jan 25, 2011 | Canon 75-300mm f/4-5.6 III USM EF Lens
My lens locked suddenly Canon EF-S 17-85mm f/4-5.6 IS USM Lens on a 20D body
Possible power problem make sure the camera has sufficient battery power and is functioning as it should (less the lens) if this is okay then the problem is between the lens and body gold contacts. It's a quick and easy repair you can do yourself. Shut the camera off remove the lens and put the body cap on the camera if you don't have a body cap place the camera on a clean lint free surface like a glass table or counter top. Use a new clean red pencil eraser to gently rub the gold contacts on the lens. Hold the lens as vertical as possible when you are doing this to minimize the rubber dust getting into the rear lens element. Clean the area of rubber dust with a puffer blower or lens cloth not a tissue. Set the lens down on the clean lint free surface and gently clean the gold contacts in the camera body keeping the camera lens mount down to minimize any rubber dust from getting into the sensor area. Clean the contacts with a lens cloth only do not use a blower/puffer, re-install the lens and it should come on. When installing the lens make sure it makes a solid click and locks securely in place.
Jan 06, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Canon EF 75-300mm f/4-5.6 III USM Lens Auto focus motor keep working back and forth but lense is not able to stop on focus right. Had eror 01 also sometime with manual focus.
If your AF motor is hunting then the lens probably needs to be looked at. I wouldn't recommend this as something to do at home so you will need to either find a repair shop if it is out of warranty or return it to Canon if it is in warranty.
Jan 17, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
When using the lens on my Canon Digital EOS Rebel XS, I get the following message: err 99
Usually a comms error between the lens and the body. Try cleaning the contacts on the lens and body with a pencil eraser.
Dec 17, 2009 | Canon 75-300mm f/4-5.6 III USM EF Lens
The auto focus will work but the motor seems to keep running after it beeps.
If this lens is Image Stabalized than the motor will run for 2 seconds after focus.
Aug 03, 2009 | Canon 75-300mm f/4-5.6 III USM EF Lens
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Canon 75-300mm USM III, was initially working fine
Try cleaning your lens contacts with a soft cloth or pencil eraser. you should see 7 pins on the camera body and lens.
Apr 29, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Canon 75-300mm f/4-5.6 III USM EF Lens Logo
876 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
