When the tv is turned on, everything is fine for about 15 seconds - then the tv automatically turns itself off. the tv is less than 2 years old.
I had a similar problem and I believe the problem is with the high voltage circuit and ccfl transformers. If you know electronics you may be able to find the chips that provide the power input to the CCFL transformer (I had two transformers and 4 FET's). You will also need a micro soldering station and excellent soldering skills to replace the flat packs (SMT). Hope this helps.
tv stays on for seconds and turns-off ---- what is going on
Same problem - turns on for about 3 seconds and then shuts off. Took it to a tv repair shop - they told me the entire panel had to be replaced - $400. No thanks - the tv only cost $275. Should i try another shop? Spent $50 on the first one.
