I have a gas heater unsure of model used for the first time in a year and it wouldn't light. This is spark controlled which you push down and turn so it flicks and obviously lights up the heater. Still no luck ended up lighting with a match which only lit one panel and when you let go of knob it went out any ideas?
Turn the gas heater off. You should notice that your air conditioning will work much better.
Posted on Jul 02, 2008
Have a richmond 6G40-36F1 hot water heater had to turn off gas for another issue, now igniter doesnt spark and pilot wont light
Not to sound silly, but are you pushing the igniter button down hard enough so it snaps? If so, your igniter is no good. Try to light the water heater the old fashioned way by using a match. I would use fireplace matches since they are long enough to reach the pilot light point.
May 27, 2016 | Water Water Heaters
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
-Pilot Won't Light- My Lite2 LG is 2 years old, but never used. I just hooked up the gas with 3/4" pipe and pressure/flow is good (I don't have a manometer tho). The pilot flame won't light (igniter is...
Open up the union in the gas line and bleed all the air out. Once done the pilot should light in a short amount of time. If it still will not light, remove the pilot and inspect it for spider nests in the head or regulating cap.
Sep 21, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
Forsaire by Williams Model 455 FEI, will spark but does not light
i had this problem a couple years ago and I had to scape where the flame lights and reset at the fuse box and it worked good luck
Jan 08, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Fan on, sparks 3 times, won't run
Shut off the gas to the heater and pull the ignitor out. Turn everything on and push the button in the door opening to get the heater to turn on. Look at the ignitor and see if there is spark across the probes when you hear the clicking. If not, replace the ignitor.
If there is, put the ignitor back in the heater and then look at the valve. The two wires that bring the 115V to the valve need to be pulled and then checked with a meter. Start up the heater again and look for the 115VAC when the ignitor starts sparking. If you see it, replace the valve. If not, replace the control board.
Jul 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Honeywell water heater. It's about 2 1/2 years old. I went to press the red button because the water was cold and it never got hot. The pilot is completely off and it won't go on after I press the red...
turn the gas valve button to piliot position, push it down and hold it, click the ignitor to light it... look thru the site glass to see the spark all at the same time, if it lights hold the button on the gas valve down for 30 seconds, let it up if it doesn't stay lit you need either a thermo coupling or a gas valve thermo coupling would be the first choice, the is also a filter around the bottom of th tank near the floor it needs to be clean that is the only soirce of air to run the heater
Apr 21, 2009 | Water Heaters
Marco fireplace Model 794 cant light the pilot
the valve handle is on when the handle is in line with valve body, off when crossed...are you pushing in on the pilot gas valve under unit? if not.. open bottom panel.. turn knob to pilot..push and hold down while sparking..if pilot lights continue to hold for about 60 secounds.. then release knob and turn to on! Also FYI... these units have a vent recall on them! please go to google and type in your heater, then model #
Mar 25, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Comfort glo propane ventless heater won't light
I have several of these heaters in my rent houses and love them. The most problem I have is not being able to ignite the pilot with the user control igniter. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
Nov 16, 2008 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
