Question about Emerson EWC20D4 Combo
TV switches to dvd mode
The tv switches to dvd mode constantly and doesnt stop for a while. the disc tray pops in and out and then freezes. then when we unplug the tv, it takes a while for it to turn back on. remote doesnt help at all..
HHEELLLLLLPPPP!!!!
if theres a way to disable just the dvd.. i would be happier than a make a wish kid at disney land!!!
ps..thx
    Problem Solver:
  • 12 Answers
Sounds like the DVD button on the remote is stuck. try taking the batteries off your remote, press the DVD buttons a few times and put the batteries back. If it doesn't help i suggest try the tv without the remote, see if it makes a difference
Posted on Jul 04, 2008
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
No picture, no sound
see the troubleshooting index:God bless you
No sound
Does not play disc
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Brand new tv with built in DVD player when you insert a DVD, it just pops right back out and will not play the disc
Hello there,
I believe you need to switch the TV to the DVD input mode before inserting a disc. There should be a button on the remote or the TV labelled INPUT or SOURCE. Try pressing this repeatedly until "DVD" is shown on the screen or use the UP/DOWN arrows keys on the remote to select DVD from the input list, then press OK / SELECT / ENTER to choose DVD mode. You should then be able to insert a disc and play it.
I need to check some details for this TV and will get back to you shortly. If the TV really wont accept any disc, then you've bought a lemon and the TV needs to be returned to the store for replacement asap. I will post back with more details below in a few minutes.
Regards,
BElectric
Mar 08, 2011 | Sylvania LD190SS1 19 in LCD TV
DVD tray will not open
I have the same issue. sometimes it opens sometimes it doesnt. I use a screw driver and pry it open as i hit the eject button. this worked for a while. But it stopped comming out even with a screw driver. I poped the pink front pannel to the dvd tray off and can access the gears that make the tray come out. you just have to use your fingure to get it started and then you can pull it out. This is not a good way to fix the problem and i will be buying a new stand alone tv and dvd player for her this x-mas. Cheap products = crappy products. It worked fine for about a year or so.
Feb 02, 2009 | Disney Princess TV/DVD Combo
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Problem with disc tray opening on its own.
if you have got something stuck in it you need to buy a new one
Oct 29, 2007 | Samsung HT-DS1000 System
Emerson EWC20D4 Combo Logo
94 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
