Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice Despenser Just Humms
My despenser does not turn anymore. I press the ice switch and it just humms. Is my motor out?
  • 481 Answers
  • the motor could be bad, the humming sound is a sign of that.
  • but i would suggest taking the auger out and make sure nothing is jamming it in anyway.
  • remove all of the ice cubes, ice buildup, or anything else that is not supposed to be in or around there.
  • it is worth a try before you start spending money. :)
Posted on Jul 02, 2008
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The door ice despenser is not working. It makes
Make sure that the bucket is pushed in all the way. If the motor is running the screw should be turning. I would also take the bucket out and try to turn the auger by hand to make sure it is turning free.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Motor humms but blades do not rotate
Try replacing the capacitor which is the cheaper option (about $20) if still don't work replace the motor.
Jul 31, 2009 | Heating & Cooling
Water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Jun 07, 2009 | GE GSH22SGRSS Side by Side Refrigerator
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore Side by Side Model 253-56953601
does it have a lockout on the despenser area that you can push to reactivate the despenser
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
