Yes i would like to fix this problem myself with your help, thanks
Could you explain in detail how im going to repair this problem, i have a soldering set and a few tools available
  • vitto187 Jul 02, 2008
    no i dont sorry
  • 790 Answers
All we have to do is to prepair the digital multimeter do you have?
Posted on Jul 02, 2008
Broken switch
which switch is broken?
Do you mean the power switch?
If so, a technician should repair it.
Please tell us your results
Good Luck
May 13, 2011 | Fujitsu LIFEBOOK N6110 PC Notebook
Sennheiser HD 205 Headphones. My cable has had its fair share of pulls and tugs over time and finally the left ear stop working. By fiddling with the cable i was able to get sound from the left ear, but...
Hi, Ian, If you have soldering experience, you might be able to replace it by yourself. If you remove the portion of the wire that is frayed and replace it with new wiring, it might work. If you feel comfortable doing this, I would say go ahead. However, it might be just as cost-effective to take it to a local audio-repair shop and have them do it. I have had multiple sets rewired myself, and it has cost less than $20 each time. Either way, it should be a relatively easy and cheap fix.
Feb 25, 2011 | Sennheiser HD 205 Professional Headphones
I have a JVC AV-65WP74 65-Inch Widescreen HD-Ready Projection TV about 7 years old. I woke up this morning to a blurry picture with strong green outlines on faces and such. I went to adjust my...
It is not ha hard repair. The average shop repair is around 200.00, but the convergence ic's are you r problem. It does require soldering. if you have solder experience the STK ICs are not that hard to replace.
Feb 16, 2011 | Televison & Video
My speedometer on my 2005 V6 mustang has stopped working - can i fix it myself - is it a cable, the teeth in the gear or what - i am a female and haven't worked on cars in years - so I need specifics like...
The speedometer on your car is electronically operated and uses information from the Powertrain Control Module to control the speedometer readout. There isn't a cable or drive system that operates them anymore. Because of the large number of possible causes for your problem you'll most likely need to have the problem diagnosed at a Ford dealer or a competent auto repair facility as there just isn't much you can do on it yourself. Hope this helps!
Nov 28, 2010 | 2005 Ford Mustang
Same convergence problem as the other guy, but...
I would not recommend replacing them yourself if you have no soldering experience,There are many smd's very close to where you need to solder that can easily be lost or damaged if you don't know what you're doing.
Aug 22, 2009 | Sony KP-51WS510 51" Rear Projection...
2001 buick regal ls - mileage dash lights are out
It is your Instrument cluster, see my answers to this question and write me if you have any more questions, it cost me a total of no more than $15 dollars to fix it myself, took be about one hour.
Jan 05, 2009 | 2001 Buick Regal
Bad convergence on my jvc model av56wp74
If you can solder and you are comfortable working inside a set where there are potentially dangerous high voltages, yes you can fix this. The problem is likely to be either bad connections on the convergence ICs or defective ICs. If you still have the results of the previous repair, please post those here and I'll provide you with additional details and instructions.
Dec 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Ge Television Repair
The repair for the tuner shield is quite simple but it might not fix it at this point.
1. Remove the back cover.
2. Remove the PCB from the where is attach to.
3. Remove the tuner's shield from the top and bottom side.
4. Locate the grounds from the shield and apply fresh solder.
5. Once the solder is done, install the shield cover back on.
The red colour before the TV went black could be related to a dry or crystallized solder at the CRT video amplifier board.
Let me know if you require further assistance.
Jul 15, 2008 | Televison & Video
Tv won't power on
Big Irish,
I saw how close to the bottom of the cabinet the main board and
all the soldering connections were and chickened out on repairing it myself. I found a local fixit shop who fixed it for $160
Thanks for the information though. I appreciate your suggestions.
May 14, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
ProScan 52" Projection Turns on the right off after clicking a few times
I've had the same problem with a 60" proscan. The tech repaired it ($400 for the repair) and left a note inside the chasis explaining what he did (in case he had to fix it again). He replaced a resistor and re-soldered a number of ICs. It happened to me again, and I may attempt the repair myself this time around.
Mar 19, 2007 | Proscan PS52800 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
